Question about GoVideo DJ530 Go Junior DVD Player
Is there a default code # to erase the parental restrictions
The only code I am aware of is the 8-8-8-8, which is the factory code, if someone else hasn't changed it already.
Posted on Feb 17, 2011
How do i reset my LG 6200 to factory or so that EVERYTHING gets erased before I give it away
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 17, 2012 | Lgic LG6200 Cell Phone
Is there a master code to reset the Parental Restrictions. I locked it a while back and forgot the code
Yes - the factory default password is 9999. This can still be used even after setting your own password. If you need any assistance with changing setting the parental lock settings, please let me know.
Regards,
BElectric
Jan 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Need to reset code
Found this on another site, from personal experience but its very well written so here you go.
The Playstation 2 is not only a video game system, but also a DVD player as well. In many families, the Playstation 2 serves as the "kids" DVD player, which means that many parents choose to take advantage of the parental lock feature to limit what kinds of movies the Playstation 2 will play back.
There could be instances where you entered in a parental code months ago, and now can't remember it. Or, you may have purchased a used Playstation 2, and you never knew the code to begin with. If you or the prior owner set a parental lock code, the Playstation 2 won't play back many movies without entering the code first. You could try to hunt down the original owners, or start inputting every code possible starting with 0000, but it's easier to reset the password and disable parental lock using a secret code.
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Please rate accordingly
Justin
Jul 28, 2010 | Sony PlayStation 2 (PS2) Console
Need master pass code to a ps2 to play movies
There is no master pass code, but there is a code to reset the parental settings. It's important to note that 7444 is NOT the password. You have to hit SELECT when asked for the password. That is where you enter 7444 to clear the code.
Oct 14, 2009 | Sony PlayStation 2 (PS2) Console
I need to get the universal code to unblock the parental block
There is no universal code, but there is a way to reset it.
Oct 03, 2009 | Sony PlayStation 2 (PS2) Console
Bought a used playstation 2-need to get parental
If this does not work, the other code is usually 0000. However if they change the default password, then it will be hard to find out.
Sep 10, 2009 | Sony PlayStation 2 (PS2) Console
Sylvania TV parental lock set by child
V-Chip info
Your personal access code will be erased and return to the default (0000) when a power failure occurs or when you turn off the power using a wall switch. If you forget the code, unplug the power cord for 10 seconds to restore the access code to 0000
Jun 15, 2009 | Sylvania 6427TE 27" TV
Parental Control Password
Use the code 7777 to erase the current code.This will set the code back to the factory default code which is 0000.
Apr 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
GoVideo DJ530 Go Junior DVD Player Logo
57 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
