Question about Dewalt Saws
How do I change the blade on a dewalt compound (12 in) miter saw?
  • 377 Answers
With the saw unplugged - The blade needs to be locked in place so it will not turn when you put a wrench on the nut located on the left side of the blade that holds the blade on. This is done with a locking pin on the right side of the blade. Push the pin in and rotate the blade by hand until the pin locks into the blade and prevents it from moving. With the pin pushed in put a wrench on the large nut on the left side of the blade and turn it. This may be reversed threaded, so you may have to turn the nut clockwise in order to loosen it. When tightening the nut after replacing the blade, you will have to once again lock the blade with the same pin.
Perhaps this video will help you locate the locking pin.
http://www.youtube.com/watch?v=oKmIB-0AE1w&feature=related
Posted on Aug 30, 2010
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
I've been using dewalt miter saw dw715 for several years and it's been working great. I just moved and today I used the saw in the new place, on an uneven concrete tiled ground. After several cuts, I...
This is common IF the blade clamping nut becomes loose... the blade will free wheel on the arbor after the motor stops. It can tear up the arbor so investigate this possibility immediately.
Feb 19, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Dewalt serial number 70170423what year is it manufactured and info about it
Dewalt 790 3.5hp
12" Carbide Tipped Blade
Miter and Compound cutting
12 1/2" Saw Travel
Serial #: 70170423
3450 RPM
Furnacs starter and reset
Steel Table with oak top
Dust Collector sheetmetal thing
120/220 volt
17/8amp
unsure year
Jan 17, 2010 | Dewalt Saws
The saw do not stop when i off the trigger
the commutator might be dirty, try and turning the brushes 180 degrees and you might have to clean the commutator with a stone for that purpose to seat the brushes.
Jan 13, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Need to calibrate my dw708 sliding compound miter saw. How to adjust the slides for a true cut. The blade is square.
i use a framing square off of the back fence with the blade down. when it is square, i check the other side of the fence and loosen the screws on the plate with the degree increments and set it to zero
Nov 21, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Wobely blade
sounds like the bearing is going out on the blade shaft
Feb 10, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Aug 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Saws Logo
428 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
