Question about Proview PL713S 17" Flat Panel LCD Monitor
PROVIEW FLAT SCREEN TFT 17" MONITOR
After recently moving house I started to put PC back together, however I have noticed that when I power up a picture does not apeear to be coming through. Green light comes on and the screen goes grey. I press adjustment buttons at the side for resolution, brightness etc but cannot get anywhere when I press another function button I get an egg timer?? do I need to adjust something or re-install drivers???
Message vga mode not support how to take it off or make it work
Posted on May 09, 2008
The vga mode not suppopt is on and not working
I have been given a ProView CY 765 flat screen monitor. How do I power it up? My only experience of computer kit that needs to be powered up, is by some sort of mains lead. I can see nothing like a two...
Usually the pin looks like a lap top power adapter cord and the slots are on the back side it could be a standard power cord that looks like a computer cord as well. It is there check the sides out as well look all over it is there. Look between where the stands upper mount underneath that area.
Please place a vote for me if I assisted you thanks for using FixYa! That monitor is your monitor picture. John
Mar 10, 2011 | Proview Pro 17 17 in. Flat Panel LCD...
Was cleaning my mouse and the screen is now having a pink/purple background. How do I fix to go back to the great colors showing as before
This is probably to do with the cables coming loss, push thecables at the back of the monitor into their housing, see if than changes the coulors.
The cables may also be loss at the back of the machine,check this by pushing the cable that runs from your monitor into your PC backinto its housing.
Mar 02, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Blurry screen on proview tft monitor
Try to adjust the picture adjustment.Like the contrast and brightness
Oct 05, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
No power to Dell E173FPc monitor; power light doesn't come on
It sounds like you are not getting any power. I would try another power cord to see if it makes a difference.
Jun 16, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
My monitor does not work right. it says vga not support.. its a proview 17" flatscreen..active matrix tft lcd
I suspect your Computers Display settings need adjustments and or a Driver from Proview installed...therefor if you can get on the net, I would look at FAQ's on Proviews Website, i.e:
http://www.proview.net/Support/FAQ_Question.aspx?pi=2026
hope that helps,
Bastian
Jun 02, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
How to use this Proview LCD Monitor 17" 700P AS A TV Screen
No. The newer LCDs can do both. But they are a TV to start with the option to hook up a Desktop.
Feb 08, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Preview 700 P
you should change al lthe caps in the PSU.. you can get them all from Maplins for a few pounds.
best get 105 centigrade ones
Oct 25, 2008 | Proview XL370B (Black) 17 in. Flat Panel...
Proview pl716s monitor will not come on
i just had this problem with my screen (proview pl716s) if you open the case and take out the power board, there are 6 470 uf capasitors bundled together and 1 220uf capasitor replace all 7 and that should fix your problem , that is what i did and it worked like a charm , oh and btw make sure before you swap your monitor from an older standard monitor to the lcd make sure the resolution is high enough becuase if it is not then the monitor will not be able to be displayd , hope that helps
Aug 16, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Faulty monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
May 11, 2007 | Proview XL370B (Black) 17 in. Flat Panel...
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
187 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
