Question about Ricoh Office Equipment & Supplies
When switching on, my Ricoh Aficio 1018 photocopyer shows ''functional problem'' Error Code SC302
  • 360 Answers
Change your charger roller
Posted on Aug 31, 2010
  • sasheevja1 Oct 07, 2010
    First check contact of charge roller in drum unit; continuity must be from hvt to charge roller edge contact
I have a problem in copier ricoh 1018 this problem
You have a corrent leak in the charge roller.
In the best scenario you could have dust in the contacts of the PCU (Fotoconductor Unit).
Try to take it off (PCU). You will see a metallic pin in the back. Clean it whit a dry coth.
Feb 18, 2011 | Ricoh Aficio 2015 Copier
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
Ricoh aficio 1018 i need to reset 541 code. when i try to erase from service mune that shows error. thanx in adv
when u reset phot/txt mode button must also be pressed with ok button. press both buttons together
Feb 22, 2010 | Ricoh Aficio 1018 Printer
Error Code on photocopier
Please clean or change the charge roller .The your problem in the HV parts.Verify the drum ground plate.
Nov 16, 2009 | Ricoh Office Equipment & Supplies
If it's an SC302 it has to do with the Charge Corona output error 3.
Grid voltage error
Charge voltage leak.
This needs to be looked at by a technician to either clean or replace the corona wire or see if there is power problem going on.
Sep 09, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
What error code 302 ricoh aficion 2016
Hi Manas,
Error code - SC302 is caused due to the leakage in charge roller.
In order to rectify the issue you need to replace the drum and the charge roller .
Nitin
Sep 11, 2007 | Ricoh Aficio 2016 All-In-One Laser Printer
246 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
