Question about Frigidaire ATF6000ES Front Load Washer
I have a kenmore 417.29042991 and it will not agitate or spin. fills and pumps water out. door lock is ok. have voltage at the speed control board.
  • 2 more comments
  • Duane Engelsgaard Aug 29, 2010
    The guide you sent to me, using the electronic drawings does not agree with the wiring I have
    in the Kenmore 417.29042991. an example : The drawings on the motor differ, and even the speed control card. They are both different from what I have. Please check this out.
    Thanks
    Duane
  • Duane Engelsgaard Aug 30, 2010
    I checked out all the above drawings but none of them fit what I have. I was checking out some parts and one site I checked was Frigidaire . I put the Kenmore number in and it came up with Kenmore 417.29042991 parts list. This indicates maybe it is made by Frigidaire. I still need your expert help. Thanks, Duane
  • Duane Engelsgaard Aug 31, 2010
    I have not been able to find any drawings that correspond to what I have.
    Would like to know what the speed control unit is supposed to put out to the motor. (voltage) (ac/dc).
    Any new info will be appreciate.
    Thanks Duane
  • Duane Engelsgaard Sep 14, 2010
    I didn't test or change the pressure switch, since I have it agitating and spinning now, but only in a
    ccw direction.
    Can you tell me what would cause it to go in only one direction?
    Thanks, Duane
  • Frigidaire Master
  • 19,396 Answers
Hi.
I don't know if you still need help with the problem, it was posted 11 days ago.
Check the pressure switch. This determines when cycle must advance in different parts of the cycle. The pressure switch is difficult to test in full. Since it is not an expensive part better replacing the switch straight away.
Before replacing the switch try also cleaning and blowing into the hose attached to the switch.
Regards.
Ginko.
Posted on Sep 08, 2010
  • Frigidaire Master
  • 8,220 Answers
The door switch has 4 wires some go to the motor control others go to the main control. It might be that the lock is working but the brain ain't gettig confirmation. Just a guess. Use this GUIDE
Posted on Aug 29, 2010
  • 4 more comments
  • Dan Webster
    Dan Webster Aug 30, 2010
    OK gotta shoot from the hip. Your product according to sears is a Kelvinator washer.
    Gotta couple more links
    Frig tumble action washer
    3.0 cu foot frontbanger
    More here
    See if any of these do it. Those service guys carry parts on their trucks and swap em out till the machine behaves. LOL
  • Dan Webster
    Go to the Frigidaire site. (User: service ----Password: tips)
    See if you can find a manual that matches what you have
  • Dan Webster
    I been watching the videos for affinity washer. Pretty cool.
  • Dan Webster
    Let me know by watching the affinity video if your machine is like it. Something is amiss. LOL
    Going to bed. Gotta get my beauty rest.
  • Dan Webster
    Dan Webster Sep 14, 2010
    I checked with some techs on this and nobody can come up with anything on my end. Try HERE
My roper washing machine will fill with water, but will not agitate, rinse or spin, but will drain. It makes a horrible noise during all cycles except when filling with water. What is or could be the...
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 17, 2015 | Roper Washing Machines
My Amana NTW4600YQ fills but wont wash
Jul 12, 2014 | Amana NTW4600YQ NTW4600YQ 3.4 cu. ft. Top...
No Agitate / No Spinning
If it is a top load washer I would check the lid switch, you should hear a click everytime you close the lid. If that is ok, there is a coupler between the motor and transmission, if it is a whirlpool, maytag, estate, admiral or kenmore.
Jan 26, 2014 | Washing Machines
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Jan 06, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
What is code F-24
E11 Fill time too long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
defective. pump.
E24 Drain pump relay on control board failed. Replace console control board.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Console control board problem. Replace console control board.
E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
E41 Control board thinks the door switch is open. Refer to test (6).
E43 Console control board thinks the door locking device has failed. Refer to test (7).
E44 Console control board problem. Replace console control board.
E45 Console control board problem. Replace console control board.
E46 Console control board problem. Replace console control board.
E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
E52 Bad signal from tacho generator. Refer to test (8).
E56 High motor current. Refer to test (9).
E57 High current on inverter. Refer to test (9).
E58 High current on motor phase. Refer to test (9).
E59 No tacho signal for 3 seconds. Refer to test (10).
E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
E5B High temperature on heat sink. Replace speed control board.
E5C High temperature on heat sink. Replace speed control board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
E71 Wash NTC failure. Refer to test (15).
E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
E75 Water temperature sensor circuit. Refer to test (12).
E82 Console control board problem. Replace console control board.
E83 Console control board problem. Replace console control board.
E91 Comunnication error between UI board and console control board. Refer to test (16).
E93 Console control board problem. Replace console control board.
E94 Console control board problem. Replace console control board.
E95 Communication error. Replace console control board.
E97 Console control board problem. Replace console control board.
E98 Console control board problem. Replace console control board.
EB1 Incoming power frequency out of limits. Refer to test (13).
EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
replace the console control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
EBE Console control board problem. Replace console control board.
EBF Console control board problem. Replace console control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Too much soap. Advise customer to reduce the amount
of soap they are using.
Apr 24, 2010 | Kenmore 43142 Front Load Washer
Maytag neptune model mah 4000 awq has clothes that are wet when done and a small pool of water in the tub (front loader), door locks, motor agitates and spins back and forth, pump hoses are clear, during...
check to see if the door locked is lit up and the door is locked. if it is not locking it won't spin full speed. the last one I had needed a wax motor to lock it and a new control board since the wax motor shorted out the control board
Nov 04, 2009 | Maytag Washing Machines
Won't spin or agitate - will pump water water out
This is caused by either a bad door switch or a speed control unit. There is no way to test the door switch but it is the cheapest to replace. Try that first then the speed control. The door lock switch hopefully does it. (even if it locks it can still be bad there is another switch inside.)
Sep 18, 2008 | Kenmore 44102 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Nov 20, 2007 | Kenmore 44102 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
109 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
