Question about Craftsman 25cc Gas Line Trimmer
Pull rope will not pull out when trying to start
    President:
  • Craftsman Master
  • 1,545 Answers
Disassembly will be required to get to the cause of this problem. This problem alongwith the rope being pulled out and not drawing back in are among the major consumer complaints.
Some may think the worst in this situation, that the engine has gone bad and "locked" up. Most of the time though, the problem is misalignment of all parts on the main shaft or the recoil unit itself. It is plastic and the shaft is steel and wear occurs. This can be fixed however but there is some teardown work involved and it does require mechanical abilities to do it.If you are somewhat inclined, start taking the machine apart (starting with the tube that holds the flex shaft that turns the string head). That would be your starting point, directly in front of the engine/coil/starter/flywheel assembly. You will need to remove the throttle cable from the carb and disconnnect the kill switch wire from the ignition coil. From there it is on to taking the front engine cover off (covers the clutch housing/clutch/starter recoil/flywheel/coil. So you see, there is quite a bit of disassembly involved to get to the starter recoil unit
Posted on Aug 29, 2010
Lawn mower rope pully repair
if rope to long then pull out recoil one turn hold rope tight pull knot out of handle down rope rope to were you are holding it tie a knot in rope slowly let rope go back in recoil then pull it all the way out should fit now cut off excess rope but also if you have a long rope it is suppose to mount on handle should be a mount hook for on the handle
Sep 05, 2014 | Garden
My yard pro lawn mower will not start, when i try to pull start it the crank rope vets pulled back sometimes
Two things to check here, check the blade is tight, it acts as a flywheel so needs to be tight, second, check the flywheel key has not sheared as this will cause the engine to kick back as the timing will be out.
Apr 25, 2012 | Garden
Rope will not retract.
I am assuming you tried to pull start and the rope is stuck out. Just try pulling the rope while it is out, but stand on the hedge trimmer. Sometimes when this happens to me, I just pull the rope a little extra and then hang onto it when it goes back in. Alot of times, I think the rope gets caught on the outside of the retraction pulley causing a tangle.
Aug 05, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
Renew pull start cord
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Nov 24, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
Cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Jun 07, 2009 | Echo Garden
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
Pull cord broke
if you have not replaced cord you will need to do this,when you fit the cord turn the pulley 4 or 5 times full circle the same way as if it was pulling cord,then feed cord through pulley and out of housing to fit handle when this is done you can let pulley recoil and you should have correct tension,hope this helps
Mar 10, 2009 | Honda Pressure Washer PSI 3000
Craftsman 25cc Gas Line Trimmer Logo
202 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
