Question about Garden
I have two briggs engines models10T500 and 10T900 with the sme problem.When started they run at a reduced speed and act and sound like there is a spark misfire.I have tried a new flywheel key, sparkplug, and ignition coil. Fuel system is good. nothing helps the RMP or misfiring
  • 1,868 Answers
Hello! The carburetor on the 10t500 is a (new #) 795477...It is a flo-jet... This carburetor has a very small fuel inlet to the bowl...When you say the fuel system is OK does that include a cleaned carburetor? The situation you described sounds like fuel starvation...Send a comment...Guru............Saailer
Posted on Aug 28, 2010
What is the frequency of Briggs and Stratton portable generator 30552-00 and if it is 60 hz and I wanna change it into 50 hz, Is it possible and how?
It be better to obtain an unit that already design for your area as it will the appropriate electrical outlets.
As for the 30552-00 would be 60 Hz with running at a governed speed of 3600 (3750 unloaded).
Being a two pole generator frequency is determined by dividing engine as follows. 3600 / 60=60. Engine is RPM is in minutes and must converted to seconds. For 50Hz operation the engine speed must be reduce to 3000 rpm (50hz * 60seconds = 3000 rpm)
Feb 08, 2015 | Briggs Electrical Supplies
Hi, I have a John Deere Z225 with an 18.5 Briggs
Although, this does sound like a fuel issue due to past experiences I want to say the problem might not be fuel at all, but before we go that route try one thing. On that particular model I believe the gas cap is vented, if so try running it till it acts up, then remove the gas cap for a moment and see if the engine returns to running normal, if not I believe your coil is going out. I have seen alot of these engines recently where the works fine but when the get hot they quit functioning all together or only function part of time which in your case would indicate why it is missing and fowling the plug. When these tend to do this after they cool back down they function properly again until they get heated up again. I hope this helps you.
Oct 03, 2013 | John Deere Garden
I have an estate 2005 20hp ohv I/c v-twin model number 13AG618G706. It starts and runs fine until I Engage the blades. Once I do that it'll run fine at a really slow pace. If I hardly press on the...
carb carb carb rebuild rebuild rebuild but as always check spark and compressin on both sides if you only have spark on one side it will sound fine untill under load
Jul 12, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Lawnmower
It sounds like the throttle cable has moved and in doing so lets the engine run at full revs, follow the cable down the the carb on the engine, the outer part of the cable will be clamped with a bracket and screw, you need the slacken the screw and push the outer cable forward the reduce the tention on it.
Jun 18, 2012 | Black & Decker Garden
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Replaced diaphram and gasket between tank and carb
This sounds like an airleak between the carb and the engine acting like the throttle is open.. Try and take some carb cleaner and spray it where the manifold bolts to the engine if you hear the engine bog or lower the rpm's then replace your manifold gasket should fix this problem
Apr 27, 2009 | Briggs & Stratton Briggs Stratton Intek V...
2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Nov 26, 2008 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
