Question about Kenmore HE2 Plus Front Load Washer
Washer will not start, Shows dl F code, clicking is coming from rear of machine
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error “dlf” or "F dl"means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Machine will not start dL code flashes
The door lock is not telling the control board the door is locked. You probably have a bad door switch or the wires to the door switch are corroded or broken.It could simply be a wire has come loose. Those washer do vibrate quite a bit.
Apr 16, 2010 | Washing Machines
F/dl code comes on - machine doesn't run
failed door lock error, i would first unplug the unit for about 5 minutes this will reset the board. if that doesnt work you may have a bad door latch. .inspect latch that the piece on the door that when you close door piece on the door makes contact with the latch. hope this helps
Sep 16, 2009 | Kenmore Elite 45986 Front Load Washer
Dl on screencliccking noise from behind washer won't run
That is the solenoid clicking. dl is a door lock error, and you can test and replace the door lock switch, but I am doubtful that will correct the problem. I really hope it does, but I have seen the dl code with the solenoid clicking at the rear of the(Whirlpool Duet) washer before and it was a faulty control board. I hope I am wrong, but... You can try unplugging and resetting the washer. In the case I saw, the machine would reset, but gradually got to a point that it had to be reset numerous times. (too many). Anyway, I hope I am wrong and best wishes. (Don't forget to test the door lock switch. Use a multimeter and check for continuity. A lack of continuity indicates a faulty switch. Hope this helped.
Aug 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer has an F dl problem?
Fdl is a code that indicates a door lock error. The clicking sound that you hear is most likely the door lock. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code dl then f
sounds like door lock issue but probably not lock itself remove top (3 screws) along back of top ..at rear of machine is control board ..if you are hearing a clicking noise at time door is supposed to be locking try wiggling connectors on control bd if i remember they are the pink wires if door locks then you have a bad connection on control bd may try wedging something under connector to help hold in place but only true fix is a control bd..good luck
Jun 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
f dl refers to a bad door lock. do you hear a faint clicking noise when you try start the machine and after maybe 30 secs of clicking the" fdl "comes up???or perhaps the door makes the noise to lock but never does lock,in which case sounds like a bad latch assy.. although the fault for the door latch it could also be the CCU not energizing the door lock. try taking off the top of the unit by removing the 3 screws along the back of the top assy (they are torx 20 screws) form there youll see the main control board mounted to rear wall and if you look straight down the right front side youll see the wiring for the door lock itself. disconnect power to unit!!!!! first unplug and replug all the wire harness on the door latch and then also the pink wires on the module itself, maybe just a loose connection. try it now see what happens
Mar 17, 2008 | Whirlpool GHW9100L Front Load Washer
Washer won't start
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer DL error
F/DL is indeed a door lock error. I had this on my machine, did a lot of research and getting some idea of how it works. The code is generated when the CCU can't lock the door. Possible causes are door latch mechanism, connecting wiring, or the CCU. I could hear clicking from the CCU on my machine which indicated to me the CCU was trying to lock the door. It tries 6 times before setting the F/DL code. I tested the latch and wiring from the CCU - OK. The clicking I heard had to be relay(s) so I figured the problem was relay contact failure. I removed the CCU board, determined which relays were suspect (there are two for lock & unlock). I changed them both and saved myself spending $300 CA on a new CCU. The relays cost just over $2 each. I found replacement relays @ Electro Sonic (www.e-sonic.com; minimum $25 order plus shipping $7.50). Relay made by OMRON part # G5LE-14-DC12 replacment for original G5LE-1-VD 12VDC. I'm not impressed to have to change a $300 CCU because of a $2 relay failure. For me this was worth the try as I have some experience working with circuit boards. The relays would be a quick repair for anyone with similar experience. Hope this helps someone.
Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
412 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
