Question about Yard Machines Red Edger
Does the yard machine 3.5 hp gas take a oil/gas mix Model#25a580a062
    Problem Solver:
  • 5 Answers
No it takes regular unleaded gass. you put oil in the oil resevoir from the top that says oil.
Posted on Sep 22, 2010
How do you mix the gas for a 3 horsepower 21 inch yard machine snow blower
Most newer machines say to mix 50:1
Do yourself a favor and mix 40:1 the machine will last longer. There is no ill effects by running a little more oil. They instruct you to run 50:1 so they can make the clean air ( EPA) people happy .. meanwhile your engine is not lubricated properly.
Dec 14, 2013 | Mtd Garden
Gas mixing with oil
first, there is a solenoid under the carburetor, that may not be working, the wire may be off or not getting power.
second, the needle in the fuel bowl may be stuck open, it's not shutting off the fuel. the carburetor may need to be taken apart and cleaned.
Jun 13, 2012 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Please tell me exactly how I mix the gas and oil for my 22 in gas hedge trimmer Ryobi Model RY39500A HT 26. What type of gas, what type of oil. Also can I buy this premixed?
If you go to your local home center in the lawn care section they will have these little plastic bottle of two cycle engine oil they treat a gallon of gas if this is your only machine that mixes gas and oil you probably will not use a whole gallon in a season and you should not keep the mixture for to long it will not last. So doing some simple math and looking at back of container try to mix the ratio down if a whole gallon is not needed. Good Luck...
Sep 05, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
Does anyone know whether these Yard Machines lawnmowers take straight gasoline or mix? I cant find an onwers manual online to clarify it. To be clear I seem to have a bit of an oddball machine;...
Straight gas. Look around, and you will see where to fill the engine with regular sae 30 oil, and on lawnmowers, if you have a place to fill it with oil, you don't mix oil with the gas.
May 18, 2010 | Yard Machines 11A08MB006 22Inch 139cc MTD...
I just bought a Weed Eater 22" gas push mower. Do I mix oil with the gas to run, as I do not see an oil input? p.s. I purchased this at a yard sale.
If it has a dipstick or plug to check the oil in the engine you do NOT mix gas and oil.
Use regular unleaded gas only and use 30 weight detergent oil in the engine crankcase if it is low.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
My B&S Yard Machine shoots out white smoke it also leaks out oil and gas mixed
If this is a 4 cycle mower (seperate places for gas and oil) and you are using a oil and gas mix as I am reading from your post that is your problem. When you use a gas&oil mix in a 4 cycle you get smoke and if fouls your spark plug. Also be more specific where the oil and gas mixed is leaking from. I SUGGEST THAT YOU DRAIN OUT THE GAS&OIL MIX AND CLEAN THE SPARK PLUG OR REPLACE AND FILL WITH STRAIGHT GAS AND SEE HOW IT RUNS.
Good luck
roundo4
Sep 03, 2009 | Mtd 22" Yard Machine Push Mower
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
Yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Apr 23, 2009 | Mtd 22" Yard Machine Push Mower
What is gas mixture for 3.5 hp engine?
do not put oil in gas just 87 octane gas their should be a small pulg or cap where you can ck. the oil.you do not mix gas and oil with that moter or it will smoke bad
Apr 20, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines Red Edger Logo
414 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
