Question about Bissell 3750 Lift Off Bagless Upright Vacuum
Bissell 3750-t part
I am looking for the plug and socket that mate when the lift out unit is placed back in the base unit. It is located at the bottom of the lift out part and the top rear of the base unit. They are a molded 2pin P&S that have short pig tails with plugs on the end of them. Thank you for any help, Bob
  • 3 more comments
  • Eric Allan Sep 05, 2008
    The plug and socket for the lift out unit burned up. I emailed Bissell to inquire about parts....hoping they will end up sending me a new vacume!
  • yeus796 Sep 16, 2008
    I tried what Eric said and they are sending a refurbished vacuum. Thanks for the help, Bob
  • rebbax Dec 26, 2008
    I am trying the email route, after reading your siggestion our 3750-T is less than 3yrs old and we noticed it smoking - so we cleaned everything and then noticed the plug and socket were completely melted, and now it will not work at all.
  • try2469 Apr 22, 2009
  • sdmalles May 16, 2009
    After a few years of light use my Bissell mod. 3750-t began smoking. I shut it down and unplugged it and after a quick look over I noticed that the plug between the lift off unit and the base had burned itself into a chunk coal. I have done an extensive search for replacemnt parts but could only find the male plug. Where can I get the matching female side? sdmalles
WOW just spoke with bissell, and they are sending me out a refurbished 3750-r. This thing has been sitting in my basement for over 5 months, who would have known.... Thanks Guys
Posted on Mar 02, 2009
Same issue, called them up and they are sending a refurb back to me.
Posted on Jun 19, 2009
I emailed Bissell and they responded quickly and are going to send me a new vacume after I send them the cord. Thanks for the solution!!!
Posted on Sep 12, 2008
Send an email to Bissell and they will send you a new refurbished vacuum. For some reason I was only able to find the male plug. So when I contacted Bissell they responded promptly no questions asked and said they would send me a new vacuum...All I had to do was send them the cord and they even paid for shipping!
Posted on May 08, 2008
No power to Bissell 3750-E
I'd test the new fuse with a meter. I'd then plug it in and retest for power and ground to and through the switch and motor. It could be as simple as a loose or pinched wire which grounded out.
Dec 07, 2013 | Bissell 3750 Lift Off Bagless Upright...
Bissell model 3750 runs well with lift off in place. But when I lift portable unit off handle there is no power to it.
Hi Will. Sorry about the difficulty with your vacuum. Please contact us for additional assistance.
Here's a quick link to reach us: http://www.bissell.com/contact-us/?cid=ccsocial
Aug 05, 2013 | Bissell 3750 Lift Off Bagless Upright...
Bissell 3750 bottom brush will not spin belt is fine and lift off works great
Hey Jessica! Please contact us for assistance regarding your vacuum.
Here's a quick link to assist you:
Mar 04, 2013 | Bissell 3750 Lift Off Bagless Upright...
I was lifting off the canister, and now there is a connector sticking up from the base. It looks like a phone jack connector. I can't reattach it. It's right in the center of the bottom of the cannister....
If the connector does not move when you gently push or pull it when you slide the canister back on the vacume it should go in place. If it is on a short piece of wire you have to gently fit it in to the hole on the other part of the vacume
Mar 11, 2011 | Bissell 3750 Lift Off Bagless Upright...
Bissell 3750-T Bagless Upright Vacuum motor is hot, noisy, and smells like it is burned out, but still working. Can I replace the motor?
There are threee filters inside this unit. Be sure all three are clean. You can't clean the Hepa filter. You can only replace it. You may even try pluging it in and running it (not while vacuuming the carpet) without the filters to see if it is clogged up anywhere. It's not uncommon to **** up an object that doesn't fit though the vaccum hose very well and for that item to cause hair etc to catch on it and plug that hose. Before you know it you have a big plug in that hose. The hose detaches easily. Look through it.
Feb 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
The plug and socket also burned on mine
bissell wont sell the parts you need any more. dont ask me why.
Jul 03, 2009 | Bissell 3750 Lift Off Bagless Upright...
Need tel number for manual
You listed this under a Bissell Lift-Off so I am assuming your looking for a Bissell manual. You can reach Bissell at (800) 237-7691or you can download your manual below. Your unit should be a 3750 or a 3760.
http://www.bissell.com/Product_Search.aspx
Dec 15, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 6595-1 with broken electrical connector
YES! If you haven't contacted Bissell yet (or bought a new vacuum) do so. They sent me a nice refurbished machine for free.
Dec 12, 2008 | Bissell 6595 Lift Off Bagless Upright...
My Bissel 3750E vacuum won't pick up.
see if the brushes are turning if not // broken belt
Oct 20, 2008 | Bissell 3750 Lift Off Bagless Upright...
Male plug needs to be replaced.
I had same problem with my lift-off, i sent email to Bissell explaining what the problem was and where to get replacement parts. They sent me emial back saying they will send me refeb replacement vacuum becasue this part has been discontinued (I think there is a prolem with lift-off and Bissell is trying to make it right for their customer without official recall). I did get my fedex lable and i sent entier length of cord from my lift-off back to them. I should be getting my refeb vacuum soon.
---Pete
Apr 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
1,241 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
