In advertantly applied 240volts instead of 115volts to power cord. Must have fried power supply or blue a fuse. Where do I get a repair diagram--electrical schmatic?
If the cord you purchased has a blue wire fused with the cord, you will need to cut off the fused portion and strip the insulation from the end of the blue wire. You will then need to connect the stripped end of the blue wire to the corresponding terminal on the new power cord.
If you are not comfortable doing this yourself, it is recommended to consult a qualified electrician or appliance repair technician to complete the wiring safely and correctly. It is important to ensure that the replacement power cord is compatible with your Dimplex dfb6016 electric heater to avoid any potential safety hazards.
There is a dead short circuit at the main power supply regulator board. Your TV need a through check-up. Contact any service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
The lightning has fried at least the power source of the tv. Even if you you replace the source there are big chances that other components/boards have been also damaged.
There is nothing you can do to it, take it to a repair shop to have it diagnosed professionally.
There is no positive or negative polarity to a fuse. A fuse is just an in circuit protective device designed to blow when there is excessive current flow. A shorting transitor, coil or numerous other components in the power supply circuitry can cause this. Take power supply to television store, this will save you a fee from them having to come out, and have them diagnose the power supply, which they are good at. You might want to consider going online and ordering a new power supply.
Typically, fuses protect the "hot" side of circuits. The reverse polarity puts the ground plane on all the power feeds in the circuit, and the normal ground plane becomes hot with unregulated voltage, which will fry anything not rated for the full supply, and it will do it before the fuse blows. There are often fusible links in small voltage circuits such as camcorders, and they're basically low ohm resisters that open up when overloaded, and act as fuses. You have to really know circuitry to spot them, or have a schematic. If you can get a used camera with a lens problem on ebay, you could probably swap out the circuit boards and get it to work, otherwise, the dreaded repair guy might have to be engaged. I've rarely seen a camera revived after having this happen to it. Sorry, wish I had better news, and good luck.
