Question about Brother MFC-5440CN All-In-One InkJet Printer
Cyan will not print
No matter how many times I clean the heads and change the cartridge Cyan just will not print. It is showing full.
  • Brother Master
  • 19,396 Answers
You need to clean the head manually with isopropyl alcohol , cotton and cleaning solution. If this does not work you will need to change the head because is defective.
Posted on May 07, 2008
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
One colour, Cyan will not print.
Some nozzle on print head is clodged. Remove the head, on some cloath, spill water and few times press head nozzles on it ( bottom side ), dry it and then do the head cleaning. If dont help change print head, when print head is changed its also recomended to change absorber and purge unit too.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Cyan cartridge prints spotty.
Your print head is probably clogged. If you have already tried the cleaning cycle, it's time to take the printer into an Epson repair center to find out what the problem is. More than likely they will have to replace the print head.
Jul 11, 2009 | Epson Stylus C84 InkJet Printer
RX680 shows ink is full but will not print lt mag, mag, or cyan
usually the problem occurs when the ink is running low and a big print job is being done. by then, the printer runs out of ink and starts sucking air into the tubes. If several cleanings dont help, try leaving it off for a couple days, turn it back on, try another cleaning and see what happens. if it still does not work, most likely the printhead will need to be cleaned which will cost about $40 - $65 if cartridges are need too.
If you are you using generic ink, that can cause the problem too.
Feb 10, 2009 | Epson Stylus Photo RX680 Printer
Canon Pixma780
Hi starge. I once had that kind of problem...Busted my head trying to fix it.....
It turn out that I bought a Bad cartridge. Brought it back to store for a new one (SHOULD be Original
manufacture ) and its fine now.
Oct 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
80 people viewed this question
James Cagle
James Cagle
Jim Keysor
