Question about Indesit 24 in. DE73 Evolution Free-standing Dishwasher
Error code I keep getting an error code R02 on my Indesit DE 73 dishwasher, can anyone tell me what this means
3 Suggested Answers
  • 4 Answers
SOURCE: indesit evolution de 73 dishwasher with an AO5 error code
a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
Posted on Jul 28, 2007
SOURCE: indesit dishwasher type no. LS12-EV03
go to this
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Dishwashers/D63.pdf
mine has stopped filling with water!
corefchaos
Posted on Sep 02, 2008
Indesit dishwasher 705. Error codes 1 and 3 (left to right) flashing. Not blocked filter as it drains water away.
Find the error code on the web so you know what the washer is complaining about (Google it). Because the washer drains water does not mean the filter is not clogged. Remove the filter and clean it to be sure.
The error code will point you to the requisite corrective action. An error does not necessarily imply failure, but it usually means just that.
Until you know what the washer thinks is wrong, you have little chance of correcting it.
Good Luck,
Pete
Jul 19, 2015 | Indesit Dishwashers
Brand new Indesit IDS105 Dishwasher will only complete pre wash cycle, on any setting.
Purchased a second hand Indesit slimline IDS105, to find it would only complete the first wash cycle, at the end of this cycle the LED Would just flash, with the waste pump coming on every 2 mins to empty it. Even after 4 hours it still didn't complete a full cycle.
I looked through the manual only to find that the error code was not explained. I phoned Indesit, after talking to 12 different people, the only thing the useless company wanted to know was whether i had warranty or whether i wanted extended warranty, then after establishing i didn't, they just biffed me on to the next, when i actually got through to a loosely knowledgable person they said they would send out an engineer for you as we are not allowed to tell you what the error code means, I just put the phone down.
So... to the solution, after dismantling the dishwasher i tested every single component, with a multimeter. Through elimination and research i had a hunch it maybe to do with the heating element or NTC Temp sensor. Tested the NTC, perfect. Tested the resistance of the heater this read 0.34ohm near enough should be around 0.29. So i took the mainboard out and tested the relay and this is where my trouble and solution arose. To test the relay i got a 12v battery and the datasheet for the relay, tested the contacts, to here a nice click....Then pop!!! NOOOO i blew the IC that controlled the Relay (ULN2003A Darlington transistor array). I ordered one of ebay (but RS,Farnell sell them for a cheaper price) Unsoldered the blown IC, soldered the new one on.
Put the Dishwasher back together, crossed my fingers, turned it on, and selected programme 2 (Normal wash) and pressed start. 1 hour and 50mins of intense tension later it had completed the whole cycle!!!!!!!! Ive never been so happy!!!
Cheers
Up yours Indesit!
Sam
Jan 16, 2013 | Indesit Dishwashers
De 73 tripping house electrics
NEED TO REMOVE AND CHECK WIRING ESPE THE HEATING ELE AND MOTOR WIRES AND LOOK @THE HEATING ELE INSIDE THE ENCLOSURE CLOSE
Dec 12, 2008 | Indesit 24 in. DE73 Evolution...
Indesit idl530 error code
go to indesitservice.co.uk and look at he online manual for the machine. it tels you what it ean in there
Jul 30, 2008 | Dishwashers
Indesit D61 Error Code 2... what does it mean?
have no access to manual. but you could...
try to recycle the power. shut off breaker or unplug for a minute or two. then turn back on. it may reset.
good luck
mark
Dec 27, 2007 | Indesit 24 in. D61 Free-standing...
Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
Nov 22, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit evolution de 73 dishwasher with an AO5 error code
May 06, 2007 | Indesit 24 in. DE73 Evolution...
Error codes
when the power is turned off for a period of 30 mins and then restored does the machine still display this error code as soon as you try and start the machine,o and by the way does the door lock?
May 03, 2007 | Indesit W 123 Front Load Washer
A13 error code
It seems to me that there isn't any problem with the normal washing cycle. The problem you have could be related to your dishwasher's detergant dispenser lid. I reckon that the relevant part isn't functioning normally. You can simply check out the claws placed on the detergant lid. If there is a spring inside, it might be damaged.
Apr 16, 2007 | Indesit 24 in. DE73 Evolution...
Indesit 24 in. DE73 Evolution Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
