Question about Video Game Consoles & Games
Cassette error, Deco Cassette system. I have an old data east system that loaded the game using a tape drive, and also had a security dongle for each game. I have matched dongles and games, but am receiving a tape deck error message. Motor hums, but the drive post isnt moving. Any chance this is simply a broken band that I can jerry-rig to fix?
The problem comes from both a faulty cassette and a faulty cassette deck.
Hopefuly both problems have been identified and they can be repaired using new parts.
You can contact me by email if you're still interested as I produced these parts (but I have a small quantity).
joseph.redon at gamepres.org (replace at by @)
Or directly have a look at gamepres.org, if you read Japanese.
Posted on Jul 19, 2012
How do I take apart the body to get to the drive of the tape cassette...??
There are thousands of happily outdated cassette players and actually you don't even specify make and model of yours so all I can provide you are these links:
How to fix cassette tape
Old cassette tape player taken apart
Disassemble the Cassette Player
Take apart tape player
Jul 03, 2015 | Audio Players & Recorders
Sharp video camera VL-AH50
Did you try cleaning the tape head?
Feb 22, 2008 | Sharp Viewcam VL-NZ50U Mini DV Digital...
What is the e10 error code on the stereo
E10 : Tight tape error
Cause: A restricted cassette tape transport or broken cassette drive belt
Correction: Substitute a different cassette tape. If there still is an error code, service the unit at an ACDelco Service Center.
If you cannot get the cassette player fixed I would recommend replacing the radio instead of going to a service center as it would be cheaper.
Jun 04, 2014 | 1998 Oldsmobile Cutlass
Why does the tape get caught in my toshiba rd-xv45kb recorder when i try to eject the cassette and the tape snaps
Not sure about the Toshiba but generally when inserting a cassette it is lowered onto the tape drive. There is a device that will register the presence of a tape which used to commonly be a phototransistor or similar mounted on a short post that is covered by the cassette.
Once the machine knows a tape has been inserted, when play is pressed two vertical rods move towards the heads dragging the tape with them enough for it to make contact with the sound head and wrap part of the way around the video head to make playback possible.
When stop, forward or reverse winding or eject is pressed those two rods move back to the starting position and the surplus tape is wound back into the cassette.
If a cassette ejects leaving a loop of tape that can mostly be pulled out little damaged the reeling in mechanism isn't working. If the tape is jammed and comes free only after breaking the rods aren't returning to the start position.
Engineers use an empty cassette case suitably modified so once the vcr cover has been removed the operation can be observed. The problem might be a worn belt or rubber drive wheel or a problem with the hidden linkages - or it might be an electronic problem.
Apr 22, 2017 | Toshiba Televison & Video
Philips DCC 600 muziek bewaren op PC
Music cassette tapes were originally used to store data in magnetic form for computers. If you have a Digital Tape deck connected to a computer, as long as you have the correct software installed on the computer, you are able to write date to the music cassette from the computer and vice versa using the tape deck.
The whole Idea of Music Cassettes came after the magnetic tape drive was invented for computers. A circular disk with a diameter of 10cm would hold 1Mb of data on magnetic tape, the drive would spin the disk from one spindle to the other and back to locate data.
An entire room of 128 of these drives was used in the first prototype of the Cray Super Computer.
Nov 26, 2013 | Audio Players & Recorders
Tape will not load; Error code 31:23
You may try the following troubleshooting steps:
Remove the battery of the Camcorder for one minute and re-insert the battery to check whether it works.
You may try resetting the Camcorder by pressing the RESET button located on it.
You may also check whether the issue occurs for all the tapes.
If the issue occurs with all the Tapes then it seems that internal parts of the Camcorder are malfunctioning.
Hence, the Camcorder requires service.
Jul 14, 2010 | Sony Handycam DCR-PC1000 Mini DV Digital...
Hitachi Camcorder VM E220A - After load cassette "TAPE" error
There is a mode switch within the deck assembly that is probably dirty but not cleanable. I haven't repaired one of those for some years and am sure spares are no longer available for it. The 58 is V8 format and should be OK but may show similar symptoms due to age, in the future.
May 24, 2017 | Hitachi i.mega HDC-401 Digital Camera
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
Video Game Consoles & Games Logo
155 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
