Question about Ruud Heating & Cooling
I'm trying to find the ball like check valve on my a/c unit to see if it is clogged. What am I looking for?
  • 43,501 Answers
That would be interanl inside the refrigerant lines at the air handler, usually by the exspansion device...
You would need to dump the chagre to get to that...
The unit will need to be pumped down and the refrigerant reclaimed by a professional to get to that...
heatman101
Posted on Aug 28, 2010
Where do the check balls get placed in the valve body of transmission?
look on spacer plate if you look close you will see where thy go
Apr 16, 2015 | 1996 Dodge Neon
1is there a plastic ball inside the Kenmore he2 plus front loader washer drain pump hose
I would not be so quick to judge it as a clog. Check valves often take the shape of a ball. In transmission and carburetors they are steel. Given that the he2 drum is lower then the drain connection in the wall it makes perfect sense for a check valve in the drain hose. If you can not see a way for it to get in there and it appears large enough to stop water form flowing back into the machine I am betting it is a check valve. Look carefully at how it might fit on the machine side of the line, if I am right, it should be able to block the hole. When water is moved toward the house drain, there should be no way for it to block the water. There is also a very good chance it is a solid ball. Look at it very carefully before deciding to remove it.
Dec 11, 2014 | Kenmore HE2 Plus Front Load Washer
What else should i try
Sounds like the check valve in the primer base is stuck/clogged/damaged, assuming the fuel lines and fuel filter are intact and not clogged, It will have to be replaced.
Jul 25, 2014 | McCulloch 2816 Edge Trimmer 28cc
I was able to use soap all last season, this year, i cannot get it to come thru, i know all about the low pressure deal, it seems to be clogged/ is there any way to specifically clean it where it enters...
Soap injectors are easily clogged or will not work because of design (air leaks will prevent chem from entering if chemical has to be drawn uphill) . They work with siphon action and will only work with very little pressure at the tip but good volume. If your siphon valve has the ball in place, however is missing the fine spring that holds the ball against seat (fine spring holds ball aginst intake fitting), the soap will not be sucked into stream. If ball and spring are in place, try elevating the soap container higher than the opening of the port (gravity feed may help to feed soap into system) . May be better to use an aftermarket downstream injector valve sold on ebay or many outlets. Cost about $20 but work better and are adjustable to save on soap. Search ebay for "Chemical Injector For Pressure Washers" or google "Pressure Washer Downstream Chemical Injectors" Various prices but lower price units work better than factory. Good luck
Jul 18, 2011 | Honda Black Max 2600 PSI Pressure Washer
I HAVE A MODEL sx55nxpcd-7443 ailess sprayer that has not been used in 4yesrs I tried to use it today I put a bucket of water for the pick up tube but nothing happens Ihave also missed placed my maunel...
When you say nothing happened.
If the machine doesn't run at all, check the cord and plug.
If the machine doesn't pick up paint, read the following:
There are 2 steel balls inside the sprayer.
The first one is in the pipe at the first joint > this ball keeps prime in the pump head.
The second ball is 5" higher, and it is opened and closed by the prime valve
These balls can rust and then the sprayer needs to be replaced
Always store sprayer filled with kerosene
The prime valve goes bad too
And the intake can be clogged with wasp nest or paint.
Let's say your prime valve is okay, and the pipe is not clogged.
Tap the pipe where the ball is located while the machine is running.
See if you can loosen the ball.
If you can't loosen it, take the pipe apart, but be careful because the ball has to fit perfectly to hold the high pressure of a paint sprayer.
If you can get the machine to prime, then tap the next ball to see if machine will fill the hose.
Oct 22, 2010 | Campbell Hausfeld Airless Spray Guns &...
Pump won't pick up cleaning fluid thru plastic suction tube.. Troy Built with 5 hp engine
The suction tube connects to a small brass piece that has a ball valve. When pump pushes water down hose, it creates suction on the ball valve. The ball valve has to be the right size. Too large, no suction, too small, no suction. The entire world of electronics is based on similar principle.
When the ball valve wears out, or gets clogged, the pump pressure is not able to lift fluid. Try cleaning valve, but my bet is you need a new part with the ball valve.
Oct 06, 2010 | Garden
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Our dyson ball vacuum keeps blowing air out of a valve at the top of the collection canister causing it to lose sucction. why?
that unit redirects the suction to that valve to protect the motor. check both of your filters and also check for a clog. make sure to clean the inside of the canister as thouroughly as possible.
Jan 05, 2010 | Vacuums
Cannot get Wagner paint spayer model 834 cw15 to get prime? Bought unit used so do not have users manual?
There is a check valve..or ball and spring inside unit that is clogged with old paint. Dissasemble the unit to repair..but make sure you can get parts first.:)
Sep 07, 2009 | Air Tools & Compressors
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Mar 17, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Heating & Cooling Logo
16 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
