Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Where i can found:-
Turbo c++ ide
  • Microsoft Master
  • 13,433 Answers
Heres one for DOS
Year 1991 is this the one you are lookin for?
Posted on May 07, 2008
Does gigabyte motherboard 915 supports 160gb harddisk
If the 160gb has an IDE interface then no. But you could use an IDE to USB adapter.
Sep 14, 2012 | Buffalo Technology 250GB MINISTATION TURBO...
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
May 24, 2010 | Microsoft Windows Vista Ultimate Edition
Turbo c in windows 7 full screen
HERE is the simple trick :To use Turbo C++ IDE in windows 7 or in Vista; For those who wants to learn C/C++ just uninstall your "Graphics driver "
For that Computers->properties->device manager->Display Adapters->graphics driver version u have uninstall that...And after log off Run your "C:\\TC\\BIN\\TC.exe".it will open in full screen...
Apr 10, 2010 | Microsoft Select Application Center...
What is the stock turbocharger on a 2001 Volvo V70 2.4T (engine code B5244T3)? The turbo is acting up and if I need to buy a new turbo I would like to buy a larger turbo to get more power out of the...
bigger is not better when it comes to turbo units as Leyland found out when they fitted a turbo to a 690 diesel that resulted in the destruction of the engines and damage to the company reputation of a reliable engine manufacturer
Subsequent engineering found that a much smaller turbo produced more power without the destroying the engine
The turbo fitted to the engine originally is the correct unit for the maximum power that the engine mechanicals can handle
What you have to do is to ensure that the variable vanes of the turbo are working correctly and there are no boost pressures lost from intercooler leaks and loose hoses
Run the fault codes to determine sensor and actuators for the existing turbo are fully operational
Jan 07, 2018 | 2001 Volvo V70
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
Volvo 940 turbo oil control valve location
take off pipe going to the intercooler from the turbo see if oil is found and clean then other pipe from incooler check it .if oil is found .drain oil in intercooler .you have an oil leak from the turbo this is why you will have light on far left of dash
Mar 01, 2009 | 1992 Volvo 940
Turbo for a V5 beetle?
hey i found somthing that might interest you. keep this in mind no matter what kind of car you have, you can always put a turbo on it, you just have to know where to look
i found this. just copy and paste it and to answer your question yes you can lol good luck and have fun
Nov 15, 2008 | 2002 Volkswagen Beetle Turbo S
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
