Question about Samsung LNT4069F TV
I have a Samsung LCD LN-T4069F. When the unit is turned on it displays a double or ghost image to the right hand side of the screen, and it has horizontal lines that make the picture appear it is separated in these horizontal blocks. After it warms up a bit the lines and images disappear. I know this is a problem in the making and eventually will fail altogether. Does anyone have a solution to this problem and where I may obtain the part needed. Thanks so much!
3 Suggested Answers
SOURCE: Samsung ln t4661f picture issues.
We have the same problem. I am afraid it is a defect that is occuring in the samsung tv's
Posted on Aug 04, 2010
  • 8457 Answers
SOURCE: My Samsung LN-T4069F momentarily shuts off and
No,this problems it is the tv Tuner signal board itself have issues.Tv intermittently shutdown and restart wright back and tv work fine as nothing wrong wright?Yes.This problems it is the tv Tuner signal board itself have ICS chips grounding issues problems.These ICS chips on the tv Tuner signal board are surfaces mounted soldering works and are not on sale indivitually ICS to the customers,even if they do,it impossible to do surfaces mounted ICS chips parts work without a 1200 degree celsius convaer belt style wave soldering machine any how.The tv still work fine wright,just used it.When it shutdown for good and don't restart it wright back again.Tries websites like, to buy a whole refurbish tv Tuner signal board for the replacement.
Posted on Apr 03, 2011
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ... > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
May 8, 2014 - Uploaded by
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Samsung vertical shadow screen
Does the screen have a double image? or is one side of the screen darker and has a delay? If so, your LCD panel is failing, common problem with older Samsung LCD's. I have the same model in my dining room that had a double image, fixed it by taking the panel apart and applying thermal pads on top of the panel tabs. The set works like a champ to this day!!!
Oct 27, 2013 | Samsung LN-T4665F 46 in. LCD Television
Green noise on all black images on my SAMSUNG LN LCD TV screen
I had a similar problem with my LG plasma. I used the Image Sticking Minimization
(Pixel Orbitor, White Wash, and Inversion) feature which is designed to prevent image burn in and ghosting. This ISM feature may be available on the Samsung or any other brand under a different name. I activated the "white wash" option for about 30 mins, the screen turns white and somehow the pixels get reset. The green noise disappeared after that.
I hope this helps. Phezbuster
Dec 20, 2008 | Televison & Video
Vertical Lines and Ghost image then powers off
If you wish to get some details; visit the site linked here. Pull up older posts. Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Mar 24, 2017 | Samsung LN-S4695D 46 in. LCD HDTV
Pink highlights on LCD screen
Jun 02, 2008 | Televison & Video
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Open Questions:
What can I buy / replace to fix my tv? I have a 4 year old Samsung LCD (LNT4069FX/XAA.) A few months ago the image started ghosting, or flickering and repeating itself multiple times down the screen, accompanied by a slight discoloration and / or darkening. At first I could "fix" the problem by gently applying pressure around the frame, or by swiveling the TV on it's stand back and forth. Once the problem was "fixed" the picture was perfect, and would remain that way until the TV was turned off, where I would have to start all over again the next time it was turned on (usually at least a few hours if not over night in between.) Eventually the turning / applying pressure did nothing. The TV would however "fix" itself after approximately 10 minutes. Again, resulting in a perfect picture and lasting until the TV was turned off. Over the course of 2 or 3 weeks, it would take more time upon start up for the problem to fix itself, 15 minutes, 20 minutes, until eventually no amount of time would solve the problem. It is worth mentioning that this occurs on any inputs, and even with no inputs - it is definitely the TV, not a cable or a source problem. I happened upon a similar complaint on your site, where the advice given was to replace the LCD converter, which I did, and the problem is still apparent. Do you have any other solutions that I may try? I would much rather fix this TV instead of buying a new one. Thank you for your time! - Jim D (the article I mentioned is here...)
May 06, 2012 | Samsung LNT4069F TV
See all Samsung LNT4069F TV Questions
Samsung LNT4069F TV Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
