Question about Canon EOS 40D Digital Camera
Error 99 come up on canon 40D...what to do to correct problem ?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
Shoot 5 pictures and get error 99
There are over 40 different malfunctions that can cause an error 99 on a Canon 40D. The 2 that account for over 95% of the error 99's are either a bad shutter mechanism or a bad mirror driving motor. It takes special diagnostic software to determine the exact cause. Otherwise, a repairer just has to start replacing parts until the problem goes away.
Bob Kilbourn www.camerarepairs.com
Oct 22, 2011 | Canon EOS 40D Digital Camera
Got Error 99 on my 40D. Have done all the obvious: remove battery, replace battery, check lenses, SD cards. Have talked with several people who tell me it's "common" with 40D. Any assistance you...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks!
Mar 27, 2011 | Canon EOS 40D Digital SLR Camera Digital...
My Canon 40D suddenly came down with the dreaded Error 99 for no apparent reason. I have tried all the usual, battery, memory card, lens, but no luck. Even on the bulb setting the shutter won't stay open....
Welcome to Fixya
Thanks
Jan 30, 2011 | Canon EOS 40D Digital Camera
I have canon 450 d i face the problem error 99 if i open flash it showing error 99 give me answer
error 99 means flash is stuck . pop the flash and when it clicks, you have to smack the side of the camera to make it pop open
Nov 23, 2010 | Canon EOS 40D Digital Camera
I have error 99 on my canon eos 40d. i have tried cleaning the gold contacts, replacing the lens, changing the battery. nothing worked. what do I do? thanks
you should google it i think you should take it to a repair shop. have fun look at this link http://www.lensrentals.com/news/2008.12.31/canon-err99 have fun!!
Feb 19, 2010 | Canon EOS 40D Digital SLR Camera Digital...
Eos 40d error 99
Error 99 can mean many things. Have you installed the latest firmware for the camera (version 1.1.1)? If you don't have, download it here (for equipment purchased in USA or Puerto Rico):
http://web.canon.jp/imaging/eosd/eos40d/eos40d-firmware-e.html
If you have the latest firmware, try this:
  1. Switch off the camera and remove the CF card and battery
  2. Keep the camera idle for 30 min
  3. Clean all the contacts of the camera (battery contacts, lens contacts etc) with an eraser. Do this keeping the camera facing down so that no debris fall into the camera.
  4. Attach the lens and insert the battery.
  5. Switch on the camera
  6. Insert the CF card
  7. If the error persists, format the card again
  8. If this does not work, try using another CF card.
Feb 06, 2009 | Canon EOS 40D Digital Camera
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
Error 99 Code on 5 month old Canon 40D
error 99 can be several things. Try the following. Check that the contacts on the lens housing are clean if not clean them with a swab of denatured alcohol available at walmart. also if there is extremely cold weather your shutter could be creating the error. Try using a blow dryer and on the warm setting warm up the camera with the lens off. Blow around the mirror area. I know it sounds silly but it has worked in the past. Good luck.
Feb 20, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
