Question about Garden
I need a manual for my Ryobi 1079r 4-cycle Weed trimmer
2strokeguy
  • 183 Answers
SOURCE: I am looking for a
You did not list which model Ryobi you have, however...
If your Ryobi has a silver or black shaft, then it is an older model and requires a 32:1 fuel mix. In the USA, that is 4 ounces of 2 cycle mix per gallon of gasoline. If your Ryobi has a yellow shaft, then it was made by HCP and uses a 50:1 mix or 2.6 ounces of 2 cycle mix per gallon.
Posted on Sep 23, 2010
bbap
  • 71 Answers
SOURCE: I need a manual for
I could not fine the manual, but here is the "Spare Parts Diagram". Hope it helps!
http://www.shouldersofshoreham.co.uk/sos_17Bamp.mvc?p=PLT2543Y
Posted on Oct 03, 2010
SOURCE: i have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
Posted on Dec 12, 2010
  • 407 Answers
SOURCE: what oil to use in
30 wt works great
Posted on Jun 20, 2011
  • 640 Answers
SOURCE: what fuel ratio do I
Check on the fuel cap or near the fuel cap. Some brands have it there, if it says at all on the equipment.
Posted on Aug 02, 2011
How do I remove camshaft from Ryobi x430 4 cycle weed trimmer
The camshaft is hydraulically pressed together and impossible get apart without specialized tools. Considering the cost of the short block I would just replace the trimmer.
Jun 21, 2015 | Ryobi Garden
What is the problem? my ryobi ss26 weed trimmer gets fuel and spark &has good compression but will not start
What is the compression reading. You have to check it with a compression gauge before you can say it has good compression. Check compression with a short hose 2 cycle compression checker. Don't use one for automotive, the reading could be off by as much as 35 psi.
Sep 01, 2014 | Ryobi Garden
Steps to run Ryobi RY34420 30cc 4-Cycle Gas Lawn Grass Weed Trimmer
This is the Cars and trucks section. You need an Expert for small engines to view this. Relist in a better catagory.
Aug 29, 2012 | Cars & Trucks
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
Need to know how much oil to mix with gas for a 4 cycle ryobi weed eater
You only need to mix oil with gas when it is a 2 cycle engine. 4 cycle engines run on straight gas. Since you didn't post your model number, here is a site you can hopefully find your owners manual at. Hope this helps.
http://odref.com/pdf/Ryobi/
Aug 23, 2009 | Ryobi Garden
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
