Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
The machine started leaking water, that collects at the base under the machine. the rest seems fine. still brewing, steaming and grinding
  • Saeco Master
  • 1,711 Answers
Their is a loose conection in one of the 8 pipe union conections of the machines. The only way to identify which one and put back in place is to desasemble the machine and let it work open in this way you can visual see where is the leak and fix.
If you leave it like this you can posible work for alonk time more like this however your are risking it to let the leaking water go over power wire and contacts and have a serius damage like burning heating elenets, motor, pump and even worst the power board.
So I sugest to proceed as above the soonest if you are able to do it or just have it repair from an engineer.
Good luck
Posted on Aug 28, 2010
    New Friend:
Mine does this periodically and turns out there is a drain behind the brew group where some water/espresso drains into the tray. Small semi-rectangular hole that is facing the back of the tray - you can see where the back of the tray is designed to receive liquid from this drain.
The drain on mine gets plugged with sludge/coffee grinds after a while and the water leaks to the countertop instead of into the tray. I simply stick a paper clip (or something pointy) into the drain hole and pour water behind and on top of the drain hole and work it to clean it out. If you have the tray in place while you do this the water and sludge can drain out into the tray as you clean it out.
Posted on Oct 06, 2013
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
My Saeco Incanto deluxe started dripping hot water from the steam spout outlet when coffee is brewing. It produces steam and hot water without any problems. It doesn't leak when it's in a normal state...
Either the grind is too fine and there is so much pressure that the pins in the steam valve are not working properly. First try to adjust grind a little coarser, it that does not work, then the pins in the steam valve need to be replaced.
Nov 20, 2009 | Saeco INCANTO DELUXE Espresso Machine
Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Nov 14, 2009 | Saeco Odea Go
Water does not flow through the coffee group but only exits viasteam pipe. Decalcifying and cleaning or resetting factory settings do not solve the problem. what to do?. The problem occurs after I have...
Hi
When you are finished with steaming, try pushing the steam button again and then opening the steam valve to purge the steam. Do this until the water flows freely. You should hear the pump change tone. If you have a pre grind button, try that without putting any coffee in the pre ground chute, then push a medium coffee. Water should flow through the brew unit freely. If not, you are getting a blockage in the brew unit. If it does, your grind on the machine might be too fine. Change to a coarser grind and try again. It usually takes 3 cycles before the grind is in effect.
Aug 22, 2009 | Gaggia Titanium Espresso Machine
Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Jun 03, 2009 | Saeco Easy Espresso Machine
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
Water not coming through espresso side although steam wand works fine
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Oct 05, 2007 | Krups Bravo Plus 872 Espresso Machine
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
419 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
