Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
Need password or key - Cisco Linksys E1000 WirelessN Broadband Router Network Routers
    Sergeant:
  • 231 Answers
If you have forgotten the security key for the router the only thing you can do is reset it however by resetting the router will reset the router to default settings keep that in mind here is a link to user manual it should help you with resecuring it http://home.cisco.com/assets/presskit/userguides/e1000_ug.pdf
Posted on Oct 02, 2010
Virgin mobile
1. Find "Change password"
  • Press Apps.
  • Press Phone.
  • Press the Menu key.
  • Press Call settings.
  • Press Additional settings.
  • Press Call barring.
  • Press Voice call.
  • Press Change password.
2. Change barring password
  • Press Old password and key in your current barring password (default is 0000).
  • Press New password and key in a new barring password.
  • Press Confirm password and key in the new barring password again.
  • Press OK.
3. Exit
  • Press the Home key to return to standby mode.
Mar 19, 2014 | Cell Phones
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
Tip
How to hack Windows password on your netbook / laptop using a USB Flash drive
Last week when my friend bought a Windows XP installed netbook, he created a complex Windows login password to bolster the privacy of his netbook. Unfortunately, he couldn't remember the spelling of his own password the next day and was unable to use his netbook. I suggested Windows Password Key 8.0 to reset the password and start using his netbook again. Let’s find out more about Windows Password Key 8.0.
Windows Password Key 8.0 is a useful application, which can be used to reset the Windows login password on your netbook with the help of USB flash drive. Windows Password Key 8.0 is compatible with all versions of Windows.
However, your netbook must have minimum system requirements to enable Windows Password Key 8.0 to reset your Windows login password. First, your Windows must be installed in a FAT-16, FAT-32 or NTFS partition and you must also have bootable USB flash drive to reset the password.
You'll need to install Windows Password Key 8.0 on any other Windows PC, which is accesible to you. Once the installation is complete, Windows Password Key 8.0 will launch on the screen.
In the Windows Password Key 8.0 window, you'll need to select the existing Windows Password Key 8.0 image, which is ideally located as a default option under ‘Choose the existing windows password key 8.0’.
Select the option ‘USB Flash Drive’ and insert your USB flash drive in the USB port. After you insert the USB flash drive, select it from the drop down list and click the ‘Burn’ button.
When the ‘burning’ process starts, Windows Password Key 8.0 extracts the ISO image and copies the necessary Windows files to your USB flash drive.
Now you can insert your newly created USB flash drive into your netbook port, and then reboot your operating system. Be sure to change your netbook set up to make it boot from your USB flash drive.
When your operating system boots from your USB flash drive, the Windows Password Key 8.0 will initialize on your netbook screen. You need to select ‘Windows installation to be processed’ and then select the user, whose password you need to reset by typing the number associated with it, followed by the ‘ENTER’ key.
In the next screen, type ‘Y’ followed by ‘ENTER’ to reset a new password.
After you reset a new password, remove the Windows Password Key 8.0 bootable USB flash drive and restart your netbook to log in using your new password.
It is always a good practice to set up a simple password for our windows login. Although we have utility applications like Windows Password Key 8.0 for our rescue, it becomes a tedious task to reset password, especially when you are travelling with important documents on your netbook.
on Jan 06, 2010 | Computers & Internet
I am trying to restore my laptop to factory settings coz I had a virus and as soon as i had pressed F10 after the Windows logo it is asking for a password. But I do not have one. Can you help?
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
How do i find out my wep key password
Welcome to Fixya. If you need your Wep Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
Mar 29, 2011 | NetGear WGR614 Wireless Router
I forgot my password for my toshiba laptop
Hi Friend,
You need to download password craker for your password...
Windows Password Key 8.0 is considered as the best tool to reset local administrator and user passwords on any Windows system. It creates a password recovery CD/DVD, USB Flash Drive for home, business and enterprise with an extremely competitive price. And most of all, it's the most popular and safe solution for removing your Windows password until now. No need to call a technician, no need to re-install anything, and you certainly don't need to reformat. It works on all and any Windows versions and computers any age
1. 100% recovery rate
2. Very easy to use, with complete screenshots
3. Supports Windows XP, XP+SP2, XP+SP3, 2003, 2000, NT, Windows XP Professional x64 Edition (64-bit), Windows Server 2003 x64 Edition (64-bit) Operating Systems, Windows VISTA, Windows VISTA(64-bit), Windows Server 2008 & Windows 7.
4. Recover or reset all user and administrator passwords
5. Reset passwords with a bootable CD/DVD.
6. Reset passwords with a bootable USB drive.(Windows Password Key 8.0 Professional only).
7. All Windows Workstations supported
8. Support FAT16, FAT32, NTFS, NTFS5 file systems
9. Support RAID/SATA/IDE/ SCSI/SAS drives
10. Supports all Service Packs
Click here for download the password tools...http://www.rosoftdownload.com/download/windows/windows-password-key-pro/
Feb 14, 2011 | Toshiba Satellite M305D Notebook
I need to change the password on my phone
To reset your voice mail password, press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
May 03, 2010 | NorStar M7310 Corded Phone
I need to reset the password . so con you tell me how to reset the password ?
To reset the password on your mailbox: press feature 983 the screen should say log:
press ok
press the Rls key
Dec 11, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
243 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
