Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refidgerator and freezer don't seem to be getting cold. Already cleaned the coils and the fan runs but the compresser doesn't.
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Kenmore Elite series side by side refrigerator serial # 79571033010
Probably low on freon(which means a leak) or a blockage in sealed system. Both costly repairs.
Dec 03, 2017 | Kenmore Refrigerators
Mdle 21571 upright Kenmore Freezer seems to run all the time and seems warm to the touch. It is keeping cold but the running all the time doesn't seem right.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | Kenmore Freezers
Lg top freezer ltn1931# doesn"t
heatman101
Jul 02, 2011 | LG Refrigerators
Refrigerator doesn't seem to be getting cold. It was making a noise and now it doesn't seem like the fan or something is not working. everything in the soft freeze draw is thawed
heatman101
Jun 15, 2011 | Kitchen Ranges
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze...
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
I hope this will help in solving the problem......
May 10, 2011 | Refrigerators
Wont get below 24 degrees only end of the coil inside the freezer seems to get cold at the very top in the back
if these coils are clean and the fans are operating then the refrigerant charge needs checked. I would also check the compression ratio on the compressor to see if the compressor has weak reed valves. this would let the refrigerant pressures equalize. and would not remove heat as efficiently as it should. This would make the compressor run alot more
Nov 19, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer cold but fridge not
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | Kenmore 64802 Top Freezer Refrigerator
My freezer temp is great but the refidgerator side is on the warm side. What should I look at?
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath or you may need freon
Aug 07, 2009 | Refrigerators
Freezer Working Intermittently; Fridge not as cold as should be
the model number you sent didn't come up,i sounds like you could have an inefficient compressor or a freon leak.when you checked the compressor was the condenser fan motor running?this is what keeps the compressor cool also clean the condenser coil too.another thing is that if you have a timer on your machine it could be sticking,if you send the model number i can tell you where it is,also if you remove the back inside wall of the freezer,look at the evaporator coil,the frost on the coil should be the same over the whole coil,if it isn't you have a sealed system problem and will need to replace the machine.if things are cold in freezer but not cold enough this is what it sounds like,do this,open the freezer door,you should hear the fan blowing,if not the evap fan motor is bad or it could be in defrost,if you don't hear the fan blowing wait around a half hour and check it again, it could be in defrost mode so the fan won't turn on until it comes out of defrost,also like i said make sure the condenser fan motor is blowing and the condenser coil is clean,if everything checks good and the freezer is cold but not cold enough and the best thing to check is the ice cream get a new machine,you have a sealed system problem.let me know what you find and good luck
Jan 05, 2009 | Kenmore 65812
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
