Question about Microwave Ovens
I have the 6107 Eagle Electric motion sensor switch, The power comes in at the sensor then to a floresent light, then to the other switch. After 4 years of working fine the lights started to flicker. I replaced the lights and it still flickers. I replaced the whole fixture and they still flicker. I replaced the sensor and the other switch..still flicker and because of the flicker the sensor sees it as motion and will not turn off all the time. Do you know the correct wiring diagrahm for this situation or any suggestions. Thanks
  • 3 Answers
This is a 3 pole switch
Black = Hot or Load
Green = Ground
Brown and Red are travelers.
Link to proper literature regarding this switch:
http://solutions.cooperwiringdevices.com/webDB/documents/cwd%20residential/instrSheets/469MT-PTA%20(REV.%20A).pdf
Posted on Nov 05, 2010
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
Is their any harm from the microwave to the person?
Yes, if it really is operating the magnetron and generating microwaves, but that is "virtually" (nearly; almost) impossible, because all microwave ovens come with a special door switch (called a monitor switch) whose job it is to cause the internal fuse to blow and kill power to the microwave. It is more likely that just the fan and light stay on, but not the magnetron, and that is caused by a different defective door switch. (All microwave ovens come with 3 or 4 door switches, and they all must work right for your microwave oven to operate.) You better call a professional repairman to have that microwave checked & repaired.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 20, 2014 | Microwave Ovens
The 13amp fuse blew in the socket and when replaced the light and fan worked in the oven however no heat was produced...any help would be greatly recived the oven is a newhomes el616.
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Start" button has not been depressed due to the wiring of the switches or it can take the mains power fuse out and stay faulty.
Check for faulty door switches and/or contaminated actuators.
Alternatively, the magnetron, supply or HV diodes can fail and take the mains fuse out.
I hope that helps.
Mar 14, 2011 | Microwave Ovens
Want to install a motion sensor into a light switch
Paste this address into your browser for RS Components:
http://radionics.rs-online.com/web/search/searchBrowseAction.html?method=browseSection&Nty=1&Ntx=mode%2bmatchallpartial&Ntk=I18NAll&Nr=AND%28avl%3aie%2csearchDiscon_ie%3aN%29&Ne=4294957972&N=4294965241&Ntt=motion+sensor+%2b+switch
You can go to their main webpage http://www.rs-components.com/index.html , pick your country and search for motion sensor + switch and select electrical wiring accessories from the results.
Feb 17, 2011 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
Frigidaire microwave will not turn on.is this a sensor problem?
inside check fuse in line with black wire and all micro switches on door and control panel
Aug 16, 2009 | Microwave Ovens
I am not getting power to the heating elements.
Maybe you should first by checking the fuse to the unit.Look around where the power cord come into the unit.The fuse may be blown.
Mar 15, 2009 | KitchenAid KHHS179LSS Convection /...
Sharp Microwave R-520L stopped working
My parents had the same problem. It turned out that a switch went bad. When you take the case off, there are 3 switches where the door latches. The bottom switch went bad. It is an Omron D3V-16G-3C25 switch.
Nov 13, 2008 | Maytag MMC5000 Microwave Oven
Microwave Ovens Logo
486 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
