Question about Ovens
Hi - I'm looking for an Instruction Manual for an Integrated Oven HJA3650. This can be branded Lamona / Diplomat / Beko (and is made for B&Q / Argos etc). Can you help please
  • Anonymous Mar 26, 2014
    user manual
    Genius:
  • 1,416 Answers
Operators Manual
Circulating Bath withDigital Controller
110-118
rev. A
Table of Contents
Section 1. General Information
1.1 Unpacking
1.2 Package Contents
1.3 Description of Circulating Bath
1.4 Specification
1.5 Circulating Bath Fluid Connections To External Apparatus
Section 2. Operation
2.1 Location
2.2 Filling the Reservoir
2.3 Reservoir Fluids
2.4 Circulator Pump
2.5 Closed Loop Circulation
2.6 Power
2.7 Setting Temperature
2.8 Setting the High Limit
2.9 Setting the Safety Thermostat
2.10 Operation of Refrigerated Models
2.11 Operation of Heat-Only Models
2.12 Selection of Celsius or Fahrenheit Readout
2.13 Optimization of Controller
2.14 Controller Display Messages
Section 3. Maintenance
3.1 Heater
3.2 Pump Motor
3.3 Condenser and Air Vents (Refrigerated Models)
3.4 Cleaning
3.5 Maintaining Clear Bath Water
Section 4. Troubleshooting
4.1 Unit Disabled - Service Required
4.2 No Pumping
4.3 Insufficient Pumping
4.4 No Cooling or Insufficient Cooling
4.5 No Heating
4.6 Insufficient Heating
4.7 Triac Failure
4.8 Controller Default Settings
Section 5. Service and Technical Support
Section 6. After-sale Support
Section7. Warranty
1.2 Unpacking
Your circulator is shipped in a special carton. Retain the carton and all packing materials until the unit
is completely assembled and working properly. Set up and run the unit immediately to confirm proper
operation. Beyond one week, your unit may be warranty repaired, but not replaced. If the unit is
damaged or does not operate properly, contact the transportation company, file a damage claim and
contact the company where your unit was purchased.
Remove any loose packing material which may have fallen into the reservoir during shipping. Also
check that nothing remains around the heater or circulator pump. Before proceeding, be sure the
Power switch is in the OFF position. Refrigerated models should have the Cooling switch in the OFF
position.
All TC-101D TC-201D TC-501D
Circulator Bath
Operators Manual 110-119
3/16in., 1/4in., and 3/8in. Nylon Barbed Tubing Adapters 510-011
6 ft. of 1/4in. ID Latex Tubing 300-299
Beaker Platform(s) for Bath Reservoir — 600 ml 701-402 701-402 (qty 2) 701-402
— 1000ml 701-403
Deck Lid(s) — solid 510-209 510-209
— w/beaker holes 510-211 510-209 510-211
Blue Hole Plugs — 31/2 inch 300-295 300-295(qty 2) 300-295
Note: Do NOT Use Above 120°C — 41/4 inch 300-296
Note: Work area "opening" is designed to measure samples directly in the bath. If additional viscometer height
i
Posted on Aug 28, 2010
Hi, i need a instruction manual for Lamona double electric oven HJA4620. thank you
Try Googling (lamona)(HJA4620)(manual) without parens.
May 07, 2017 | Ovens
I need Instruction Manuel for A Diplomat ADP3120 Softline 600EM Lamona fitted oven
Google it or ask the manufacturer if they have one available
Sep 09, 2016 | Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Diplomat 910-need instruction/fitting manual
Eventually I have tracked down the manual on ebay-it is available through the seller ' usbdesarch' who appeared to have a selection of manauls available.  If I can post a copy on here when I recieve it I will though I'm not sure how to upload a PDF? Any ideas how I would make this available to the widest audience? I have no website to host the file from.
Jun 02, 2009 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
DIPLOMAT SELECT 920/AHY4401 S/S OVEN MANUAL
I have a copy of the Select 920 double oven instruction manual. Send an email to sharemonger@tiscali.co.uk and I will reply with a copy in .pdf file format.
Dec 24, 2007 | Ovens
Ovens Logo
778 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
