HP printer/new Acer computer
My printer is in good condition and have never had a problem with it but is not printing properly with new computer. I have been told that they can be made compatable. Can you please help me
  • 796 Answers
Can you please mention the printer model and the operating system which are using...
Posted on May 07, 2008
HP ink jet 1200..prints only test page after replacing the yellow cartridge.test page only shows black and blue inks are good.need help.
Important thing: HP inkjet printers having self align technology & its aligns automatically after replacing the ink cartridge/s.In the process of align it will prints align page &it will read it on the model.
Suppose if you replaced yellow cartridge, as usually it will print align page, but if one or more cartridges not printing properly align will not completes. Results every time it will prints the align page when its switching on. Align will completes only when all cartridges/print heads are in healthy condition.. Check the alignpage find out which colors are not printing properly, replace it to over come from this issue. Now you decide what to do?..
Dec 11, 2012 | HP Inkjet 1200dn Printer
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
How do i clean the hp printer's in order to get a clean and darker print?
Print quality depends on cartridge health condition only, especially in inkjet printers.*Print head clogging: Usually white horizontal lines in print outs due to print head nozzles are clogged. Printer it self having self cleaning mechanism to clean the nozzles while printing & powering on..And "clean nozzles" option also designed in printer drivers for cleaning. And last option is manual cleaning. Alcohol is good solvent & best for cleaning the nozzles,use cotton or ear buds to swab on the surface of the nozzles with alcohol gently.. You will get good quality print outs if cartridges are in good condition..(see the snap shots)Other parts to clean: Encoder,disc encoder, service station & rollers needs to clean periodically to avoid malfunctions & paper jams.* Encoder's malfunctions: If any vertical or horizontal crooked print outs observed, clean both encoders needs to clean.. (see snap shot for encoders)*Service station malfunctions: If any carriage jams observed in service station, remove & clean it ..(see the snap shot)*Rollers malfunctions: If media is not picking up properly it causes jamming error,clean or replace the rollers..
Dec 31, 2011 | HP PSC 1315 All-In-One InkJet Printer
Hp laser jet all leds on and not working
The surge protector or UPS may not be allowing sufficient voltage through to the printer. HP printers do not have built in speakers of any kind. Because of this, they are not capable of making any beeping or squealing sounds. If any noises such as these are heard then the printer is probably connected to an Uninterruptible Power Supply (UPS) or a backup battery. To verify that the UPS is the source of the noise, plug the printer directly into a wall outlet bypassing the UPS.
The following are common symptoms:
  • High pitched squealing, beeping sounds, or alarms (UPS)
    NOTE: Noise over the phone line can also cause high-pitched squeals and beeping sounds.
  • Inexplicable or false error messages
  • Printer will not "wake up" from sleep mode
  • Printer appears to be DOA
  • Incorrect printout
  • Slower than normal printing
  • The printer control panel display is blank or shows garbled characters
  • Accessories, such as attached copier/scanners, do not function properly
  • Monitor loses power or shuts off
  • Computer reboots when job is printing
  • Job only prints half way, causing a paper jam
If it is necessary for the product to be connected to the above-mentioned devices, consider the following items:
  • There are many UPS configurations and load conditions that can affect proper printer operation. Depending on these configurations or load conditions, printer functionality cannot be predicted.
  • No damage to current HP LaserJet products will occur, but, depending on their particular UPS configuration, the printer may or may not operate properly.
  • Printing while on a UPS battery backup is not recommended because of the large power requirements of HP LaserJet products.
  • If the HP LaserJet printer is not operating properly and power line conditions are suspected, try a different circuit (a different wall plug located away from the current one), or try removing it from the UPS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | HP LaserJet P2015n Printer
Hp photosmart 1215 printer will not print on my new acer computer. It works fine on my old computer.
Resolution1:
For WinXP:
1. Click Start>>Run & type msiexec /unreg then Press OK.
2. Click on Start>>Run & type msiexec regserver Press OK.
3. Unplug & Re-Plug the printer & try to print.
Jul 21, 2008 | Acer Computers & Internet
My Laserjet 1018 will not start
HI,
Can you please describe your problem?
Jul 12, 2008 | HP Office Equipment & Supplies
My power on light of my f4140 HP printer is blinking
please hold down power button for 20 seconds so that hp printer shuts down and reboot again and try and see what happens
good luck with it if that doesnt work go to device manager then remove the printer and remove all printer software and then unplug printer reboot computer then you plug in printer then let the windows software load all drivers they will work fine once you install the new software go to windows update website then look for updates for new hardware items you are good to go reboot and happy printing
Apr 07, 2008 | Computers & Internet
I have just connected a HP Deskjet 3940 to my new acer computer and it is not printing. I went in print then options and clicked on a few things but still not working. Have new cartidges in 22 and 21
un install the printer driver,reboot ,windows should detect new hardware ,and then insert the cd that came with the printer select have disc and re-install the software.
if your acer has vista you may need to get a vista driver for it,or worse the printer is not compatible with vista.
good luck
Terry
Mar 12, 2008 | Computers & Internet
Unable to communicate to a 1320n laserjet printer
unistall the driver completly and install again so after that click shared printer and them try it
Sep 25, 2007 | HP LaserJet 1320n Printer
61 people viewed this question
jasbo
jasbo
