Question about Hitachi 43UWX10B 43" Rear Projection Television
When tv is on picture will suddenly go off and red led power indicator flashes on and off. When you turn tv off and wait five minutes or so you can turn it back on . Happens once per day.
  • amadera Aug 31, 2010
    There are NO convergence issues or for that matter ANY other issues except what was described. Shall I check the resistors?
  • amadera Sep 09, 2010
    No real pattern....sometimes it will go three or four days without doing it at all. If you turn it of when it happens , 5 minutes or less and it's back on with no recurrence 'till the next day or two or three.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
There are some things to look at here, does set have any convergence issue when it is on, see photos.
Second, with back removed look at photos of resistors, are any discolored?
SD TECH
The next is photos of heat sink on right side as seen from back, look carefully at the resistors, are any discolored?
This is view from right side of same area.
Posted on Aug 28, 2010
  • SD Tech
    SD Tech Aug 31, 2010
    Yes, take a look at them anyway.
    Also is there a pattern to how long it will play? What is the longest?
    It may be a bad solder connection somewhere that opens when the board gets warm.
    SD TECH
  • SD Tech
    SD Tech Sep 09, 2010
    To be honest you may just have to wait until it either gets worse or fails completely, unlike some sets this one does not have a error buffer which would record what area failed.
    Sets that play for days can be hard to fix; even in a shop they would have to run it with back off and when it fails inspect voltages and check for bad solder connections in several areas.
    A set that just does not work is much easier than something like this.
    SD TECH
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
Hitachi 43UWX10B 43" Rear Projection Television Logo
13 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
