Question about Sunbeam Heritage 4264 Iron with Auto Shut-off
The iron make a buzzing noise when trying to start it
The Iron makes a noise when it is first plugged and everything is in the off position
shouldnt happen if iron dials are set to zero
if its a fizzing type noise
best plan is to replace the iron
Feb 28, 2017 | Irons
Hadn't used my iron for 2 months.
yes, it's possible, try cleaning it again and see if you get the same results..
May 06, 2016 | Irons
Steamer buzzes intermittently when ironing even when tank is full
this is normal i think, my iron does this as well
Mar 15, 2016 | Irons
Boiler on the iron was empty,used by someone that didn't know this type iron.Turned iron on and later heard this awful noise and husband tried to release pressure and cap blew off but no water was in...
I do not use this model, but it would appear the iron is not affected, just the boiler - like setting an empty tea pot on a hot burner.
Is there any warning that the tank is empty before turning the iron on?
I would refer to the manual for cleaning before using the iron and would not loan anything more valuable than a cup of sugar to anyone.
Mar 19, 2010 | Rowenta DG5030 Iron
Hand steamer conair GS15R will not produce steam. It is on, it is full of water, the body gets warm, and it makes noises like it is steaming but nothing comes out.
Hi.
The iron steam lines may be clogged with limescale.
Try first using descaling solution to clean the lines.
Do descaling several times.
If that does not work, then the thermostat may have started malfunctioning and cutting off earlier than normal. This will cause water not getting enough temperature, and iron not steaming.
Try using a descaler product, often that can fix the problem.
Jan 14, 2010 | Conair Irons
Started to make a funny noise when you first switch on, now trips out electric
unplug and toss. replace. has a short somewhere in unit. better safe than sorry!! if still under warranty- get it replaced!
good luck- stay safe!
Oct 04, 2009 | Euro-Pro Steam Generator EP8001 Iron
Iron stopped working suddenly
perhaps the thermostat is sticking.as irons are cheap to replace i would try cleaning /soaking the tank to remove lime scale. or strip the iron down checking thermostat and conections.
May 01, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Rdgs
Alan
Nov 27, 2007 | Rowenta Perfect Iron
Sunbeam Heritage 4264 Iron with Auto Shut-off Logo
121 people viewed this question
Top Sunbeam Irons Experts
Tony
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
