Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag top loader not spinning
I've been having an intermittent problem for the past few months, the washer was only spinning out my clothes with small loads. Now it won't spin at all and I smell something burning. I've replaced the belts, but nothing. Read a couple of forums and they mention the motor, spin solenoid and drive coupling. Do you think it's worth me pursuing this myself or should I just get a new washer?
Thank you in advance
  • faith3204 May 07, 2008
    Hi Julian,
    Thank you for the opinion. I looked up the directions for replacing the motor and think I'll buy a new one instead. But thank you anyway.
  • 975 Answers
Thats correct , need to replace the MAIN MOTOR, all that you mentioned (drive coupling , spin solenoid) there inside the MOTOR , since they manufacture the MOTOR sealed, it makes it impossible to repair , so if your handy with tools I suggest to get a new motor or a refurbished one , price range from $35.00 up to $90.00 , hope this info helps , AJ
Posted on May 07, 2008
Maytag top loader washer unbalaced during spin cycle
check your load -- not enough clothes in it - too little heavy ones
Jan 13, 2014 | Maytag Bravos MTW6600T Top Load Washer
Need manual for maytag washing machine model As11
probably needs a belt. pull the washer from the wall and tilt it back against the wall, make sure it is stable. then look under and find the belt and replaced from a local vendor.
Jan 02, 2012 | Maytag VRSCDX Night Rod Special Washing...
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
3RLSQ8000 Top Loader
Make sure the lid switch is making good contact throughout the spin cycle.
Jan 15, 2009 | Whirlpool LSQ8000 Top Load Washer
Makes a grnding sound when washing(not always) & does not spin all the water
This problem happen to me a few months back--washer was 6 months old. A technician came out and told me that I must have loaded the washer after the water was in the tub. He stated that I must load my washer prior to running the water in because the water fill amount is based on weight; therefore it was now weighing too much. Go figure...have always loaded the washer with water first and clothes last. I always put clothes in first then the water--I must say, the problem has not reappear.
Hope this helps.
Nov 03, 2008 | GE Profile WPRE6100G Top Load Washer
Washing machine spin cycle
chances are the pump may have something in it or the drain line is kinked a little front loader machines have a clean out on the pump that you can get to buy taking the lower front panel off.top loaders you have to pull access cover in the rear and pull hose off and check for blockage also check belt tension and quality of belt
Dec 16, 2007 | Maytag MAV7600 Top Load Washer
Lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Oct 27, 2007 | Maytag PAV2300 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
61 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
