Question about NetGear VS-WGR614 Wireless Router (vswgr614)
NetGear WGR614 Wireless Router
I have all the wires hooked up as shown on the smart wizard cd.....yet still when i click the next button .....it tells me there is no network detection but i can still get on the internet.......im trying to get to the settings where i can configure my xbox 360........any idea how i can bypass the install wizard and just go to the router settings on Windows Vista
  • Serwen Bagadiong
    Serwen Bagadiong May 11, 2010
    Is the XBOX360 going to be wireless or wired to the router?
    Master:
  • 441 Answers
On the setup wizard choose "No. I Want To Configure The Router Myself." (by going to http://192.168.1.1 as per HellaNice
The username is admin and password is password.). Once your on the setup page go to the port forwarding and open the ports for your XBOX if thats what you need.
Posted on May 09, 2008
    Champion:
  • 230 Answers
Default access to router is http://192.168.1.1
login/password is with your instruction booklet.
Posted on May 07, 2008
I can't find my CD to set up the router. I have cable internet modem set up and working fine. I can't locate free driver download without getting stuck in a "free" service that charges for...
I found the below information at Netgears website http://kb.netgear.com/app/products/model/a_id/2590.
I hope it is helpful,
Shawn
Lost or Unable to use Router Configuration CD NETGEAR does not replace lost or broken CDs because the Smart Wizard installation and configuration utility on the CD is already built into your router management software. There is no need to download anything to replace the CD - everything you need is in your router. This is true even if:
  • the CD that shipped with the router has been lost or cannot be read, or
  • errors occur when running the configuration program, or
  • the router is not connected to a computer using the Windows operating system.
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
A video walk-through of installing and configuring your router using the Smart Wizard is available at http://kb.netgear.com/app/answers/detail/a_id/12873.
Jan 29, 2011 | NetGear WGR614 Wireless Router
How do i hook it up
Netgear WGR614 54Mbps Wireless Router
  1. Begin setup of your Netgear Wireless Router by first reading the instructions in the included manual, and following their guidelines for plugging in and initializing the access point. The first few steps in this guide should coincide with the information found in the manual, however we will follow up with important information on how to secure your wireless access point.
  2. After powering up the router, use an ethernet cable to connect your computer to one of the ports on it marked 1 through 4. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. This will take you to the Netgear Smart Wizard welcome page, click OK to begin the configuration. The router will attempt to detect the type of connection you have and the next message you receive should be Dynamic IP (DHCP) Detected, click Next once you see this.
  3. Next you will enable the wireless capability of your router. In the dropdown box for the region where you are located select United States from the list. On this screen you should also change the Wireless Network Name (SSID) from its default value to something unique so that your Base Station will not be confused with another. Click Next.
  4. You should now see a message confirming that your connection is working and wireless is enabled. However, your are not secured yet. Read the notes and click Done. Then direct your browser to http://www.routerlogin.net to continue the configuration. A window will pop up prompting you for your login and password, enter admin for the username and password for the password, then click OK.
    Accessing the router settings through a web browser.
  5. Once you have logged in you will see the main configuration page (shown above). Now click on the Wireless Settings at the left of the page. In order to password protect your wireless network select the WEP (Wired Equivalent Privacy) option under the Security Options and then under the Security Encryption (WEP) section that appears, select 128 bit next to Encryption Strength. Choose a password between 6 and 8 characters and type it into the Passphrase box under the Security Encryption (WEP) Key heading. Then click Generate. Finally click Apply. You may also select WPA encryption, however not all network cards support this, so check your documentation first.
  6. Next look for the Advanced section heading on the left side of the page and click on this Wireless Settings section. Disable the SSID broadcast option by unchecking the second box in this section and then click on the Setup Access List button.
  7. On this page (seen below) check the box to Turn Access Control On and click on the Apply button to save this setting.
  8. Now click on the Add button, this will display a Wireless Card Entry heading. This is where you will choose a name and enter a MAC Address, also known as Physical Address, for each computer that you will be using to connect to your wireless network. If you don't know how to get this information follow the steps here. Once you have finished, click the Apply button.
    Creating an Access Control List will prevent unauthorized computers from using your connection.
  9. Finally click on the Set Password link on the left of the page under the Maintenance heading. Change the default password for accessing your wireless router setup pages by first typing the old one, password, into the appropriate field and then entering a new one into the New Password field and confirming it. This should be a different password than the one you setup for WEP encryption, but should also be atleast 6 to 8 characters in length. Click the Apply button.
  10. Your Netgear Wireless Router is now secure.
Jan 07, 2011 | NetGear WGR614 Wireless Router
I lost my password to my netgear. How can I retrieve it?
Go to NETGEAR Router.
After connecting the Router into your network, you must configure it. You can do this using the Smart Setup Wizard -- where the wizard will attempt to auto-detect the type of Internet service you have through your ISP -- or you can configure the router manually. It is recommended that, if you aren't used to setting up Internet connections, you let the Smart Setup Wizard do some of the work for you.
To configure the router, you'll use the information that you filled out earlier in the Installation Guide.
To get started:
  1. Select Yes if you want to use the Smart Setup Wizard.
    or
    Select No to configure the router manually.
  2. Click Next.
Nov 06, 2010 | NetGear WGR614 Router
Where i can download set up cd for my wireless router becouse i lost my
Follow these steps:
Oct 30, 2010 | NetGear WGR614 Wireless Router
How to set a password for netgear
  2. After powering up the router, use an ethernet cable to connect your computer to one of the ports on it marked 1 through 4. Next open a web browser window on the connected computer and typehttp://192.168.1.1 into the address bar and press enter. This will take you to the Netgear Smart Wizard welcome page, click OK to begin the configuration. The router will attempt to detect the type of connection you have and the next message you receive should be Dynamic IP (DHCP) Detected, click Next once you see this.
  4. You should now see a message confirming that your connection is working and wireless is enabled. However, your are not secured yet. Read the notes and click Done. Then direct your browser tohttp://www.routerlogin.net to continue the configuration. A window will pop up prompting you for your login and password, enter admin for the username and password for the password, then click OK.
Aug 23, 2010 | NetGear WGR614 Wireless Router
Netgear WGR614 wireless problems.
  6. Next look for the Advanced section heading on the left side of the page and click on this Wireless Settings section. Enable the SSID broadcast option by checking the second box in this section and then click on the Setup Access List button.
Also check to make sure you are broadcasting your router, in the settings (Step 6). This will not hide your router from devices that you want to connect, such as mobiles and consoles, which is what you want to do.
Jan 03, 2010 | NetGear WGR614 Wireless Router
Can't Firmware Upgrade my WGR614V9 from Initial Versio to a New 1
You can go to the Netgear WEB site to download drivers, firnware upgrades etc. click on this link to their WEB site :-
Nov 15, 2009 | NetGear WGR614 Wireless Router
NETGEAr support
not sure exactly why you would need the setup software... you should be able to plug it in and access the routers firmware and set it up that way.
here is the link to the site for your hardware.
http://kb.netgear.com/app/products/model/a_id/2591
Jun 01, 2009 | NetGear WGR614 Wireless Router
How to install Wireless-G Router to my gateway computer.
There is a link called, "View Smart Wizard Install Assistant Flash Demo" on this site to help you install the product.
http://www.netgear.com/Products/RoutersandGateways/WirelessGRouters/WGR614.aspx
Please rate the solution if this solves your problem.
Mar 29, 2009 | NetGear WGR614 Wireless Router
NetGear VS-WGR614 Wireless Router (vswgr614) Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
