? 13:13
https://www.youtube.com/watch?v=CBqP-Q86UyM
Jul 9, 2014 - Uploaded by GotNoEvidence
Here is a fix that does not involve disassembling your camcorder, sending to the ... This worked for us when the tape door wouldn't close on our old Sony HDR-HC9. .... is you can use the same method to REMOVE a tape when the tray will not lift! ... Yes yourvideo helped me fix my DCR-HC96 camera.
there could be a bad or not totally depressed door switch/es when all doors are closed, assuming the alarm system module (not sure of the name, some manufacturers call it body control module-'BCM') is good. you may try the following:
1. if there is, tighten each lock nut (or mounting nut) of the door switches, to bring out each door switch so that they will be fully depressed when the doors are closed.
2. to find out which switch/es is not being fully depressed when door is closed: while (& all doors closed) door ajar alarm is on, open one door & manually depress the door switch (try to depress several times - might be sticking). if alarm turns off you found the switch, otherwise continue to the next door. but before proceeding to the next door, tape down that first door switch (you may have more than one?) once you found the switch that is not being fully depressed when door is closed, tape down that switch (to keep the alarm turned off). go back to each taped down switch. remove tape & close door, if the alarm turned off when the door was closed (switch is fully depressed=good), then go to next.
3. you can skip 2, just install spacer to doors. spacer can be a thin piece of plastic (or something weatherproof cardboard) to make the door switches to fully be depressed when doors are closed., not too thick that may prevent door from properly latching). tape them first, then use good adhesive if they work.
other possible causes are bad door switch, broken or detached wire, or bad BCM)
(note: the door switch is a push button which looks like a small protruding nail? & mounted at the door opening, which will be depressed by the door upon closing).
bit late...but. STOP ASAP! by removing the battery, after removing battery, wait 20 seconds, re-fit battery & CLOSE the cassette door.
then wait 10 seconds, slap the closed door twice quite firmly. then open, if it opens, discard that cassette tape, clean the players head using cleaning tape.
use new cassette tape.
I see your picture of a cassette player. Guess you are referring to that. (tapes also come in reel-to-reel, and 8-track). Just push the "EJECT" button (power may need to be applied to some units for the eject button to work). The tape slot will open. Insert tape with exposed tape on the "head" side of the opening, usually the heads are on the bottom of the slot.. You can't put it in any other way and have the door close. The "door" that opens has guides for you to slide the tape into. The side you want to listen to should face you. Either manually close the tape compartment or push the close button (depending on model). If the door doesn't close, you put it in upside down. Push play and enjoy.
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder 1. Per the manual on esupport.sony.com - if the power is disconnected door won't open, and if the battery is the dead the door won't open. Plug it in and hopefully you can get the tape out.
alot of cassette tape deck doors actually come off, they clip onto the inner door assembly, if the outer part isnt clipped on correctly, it may shut without a tape, but not with a tape inserted, try to see if the outer door is clipped on there correctly, jim d
hi there, i have exactly the same problem but on a mv750i !!! If i put a tape and close the mechanism motors stars working but it doesn't go in... if i close it without a tape the motors doesn't work... is any possible way to manually push it in ???
I'm having a similar problem. The camera is a Sony
DCR-TRV280.
When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down.
In other words the mechanism works fine without the tape but with the tape it doesn't.
I hope the explanation is clear enough.
Thanks
