Question about Kitchen Ranges
I need help removing the filter assembly over the sump area in the bottom of my LG LDF7923ST Dishwasher. I believe there is something caught in this area and I want to get it out. I have removed the spray arm and the nine screws. Since this is all plastic - I do not want to break anything - how hard and where should I pull on various parts to remove them. There is an arm that extends out the top back of the filter cover that needs to be removed. I believe it carries water to the top arm. Can I just pull it up or is there something I need to do to remove it?
  • marysuec Aug 28, 2010
    Daniel,
    Please see my original questions as you didn't address them.
    You did not tell me how to remove the arm that extends from the back of the dishwasher to the top of the filter. This arm has to be removed before I can remove the filter assembly.
    Mary Sue
  • marysuec Aug 29, 2010
    Daniel,
    No - You gave me instructions about the top spray arm.
    I need help with removing the arm that is attached to the back of the sump filter/cover on the bottom of the dishwasher. It is not a spray arm. It is a arm that covers over the water line that leads from the middle of the bottom of the dishwasher up the back wall to the top spray arm.
    It has to be removed before the filter cover can be removed. I need to know how to remove it.
    Mary Sue
  • Kitchen Ranges Master
  • 3,083 Answers
These things get so gummed up with a buildup of impurities so it's always hard to figure it out, and even if they don't have any attachment bolts, they can get "cemented" in. Here is a web blog with pictures, not of your unit, but it might give you enough of a hint:
http://www.handymanhowto.com/2010/04/25/how-to-replace-a-dishwasher-part-1/
Not sure if this LG problem relates to your situation, but it might be worth reading...especially the paragraph at the bottom of the page:
http://hubpages.com/hub/LG_Dishwasher
Good luck, hope this helps, and thanks for using FixYa.
Posted on Aug 29, 2010
  • 4,323 Answers
Hi
Turn off power to the dishwasher and unplug it or shut off the breaker to disconnect the power. Now remove the bottom dishwasher rack and remove the bottom spray arm. Now take out the screws and pull out the entire filter assembly and the mesh on top of the sump. Inspect for any debris or restrictions and make sure that its not locked up. Remove debris that is blocking the impeller. While reassembling pay attention towards gaskets in the filter assembly, they should be intact and in the proper position.
Also check this link for details---
Sump pump picture link 1
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 28, 2010
  • Daniel Scott
    Daniel Scott Aug 28, 2010
    To remove the top spray arm follow the instructions----
    · Open the dishwasher door, and fully extend the top dishwasher rack. Look for the plastic ends of the slides on each side of the rack. These plastic tabs are holding clips. The clip uses a tab that installs into a slot in the side of the track while the main portion of the clip covers the end of the track.
    · Press the rear of the tab from the outside of the rack with your thumb while simultaneously pressing the main part of the tab toward the rack. This releases the tab from the end of the track. Remove the opposite tab in the same way. Pull the rack out of the glide track and away from the dishwasher.
    · Pull the rear clips out of the back of the glide track. The rear clip pulls straight out from above the glide track. Pull the glide track out of the rollers mounted to the inside wall of the dishwasher and away from the unit. Fully extend the moving glide track, and remove the screws securing the stationary track with a Phillips-head screwdriver. Remove the glides from the dishwasher.
    · Turn the rack upside down, look for the seam between the spray arm and the plastic tube running down the center of the rack. Insert a putty knife between the seam, and pry the spray arm free. Pull the spray tube straight up to unclip it, and remove the tube from the rack.
    Daniel
I have a grinding noise when I first turn on my dishwasher what can I do to put this right
You've got something caught in the drain pump impeller blades. Remove the filter assembly on the inside bottom of your dishwasher and see if you can clear out the object stuck in the drain area.
Pro tip: Wet-vacs work wonders sucking out glass from drain pumps.
If you still can't clear it out, then you'll need to get under your dishwasher and remove the drain pump to clear out the debris.
Nov 15, 2014 | Dishwashers
The washer fills and runs through the cycle but leaves a grit on the dishes
If detergent is left in the compartment:
? Be careful not to load items so close to the dispenser
that the cover will not open to release the detergent.
? The dispenser is not supposed to open when you
use the Rinse program.
? Your dishwasher detergent should be fresh and
stored tightly closed in a cool, dry place. Old or caked
detergent should be thrown away because it will not
dissolve properly and will leave a gritty residue on
the dishware.
? Wait until you are ready to start the dishwasher to
add the detergent.
? If you are using the Delay program, make sure the
dispenser is dry before adding the detergent.
? The detergent compartment only opens in the main
wash programs, not the Rinse program.
YOU MAY NEED TO CLEAN THE FILTERS MORE OFTEN
IF YOUR AREA HAS HARD WATER
This can cause low water pressure.
In hard water areas, it may be necessary to clean chemical buildup from the filters every 12 to 18 months. To do this, remove the coarse filter by squeezing the
tabs and lifting it out. Next, unscrew the fine filter and lift it and the main filter out. Wash all three filters gently in hot, soapy water and rinse them thoroughly.
Your spray arms may be clogging causing low pressure too.
Spray-arm jets and bearings may sometimes become clogged with hard water chemicals. To remove the spray arms, screw off the nut and take off the washer on top of the spray arm and lift off the arm. Wash the spray arms in warm, soapy water. Use a soft brush to clean the jets. Rinse thoroughly and replace.
Try cleaning the drain pump so it gives you more water pressure.On occasion something may get through the filters and into the drain pump. The drain pumps on ASKO dishwashers are designed to automatically reverse if anything should get caught in the propellers, thus ejecting the item back into the sump area or down the
drain. Should you need to remove an obstacle from the drain, first turn the power off then remove the filters . Next, lift out the small black insert
from the sump area. (You might want to remove any standing water first.) You can then look into the sump area for the item causing the obstruction. Should you
find something, simply scoop it out. Be sure to replace the black insert before you put the filters back in.
You could also try to clean the dishwasher with ' Dishwasher Magic '. This would work like charm :-
http://www.dishwashermagic.com/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a GE Nautilus dishwasher. I recently started hearing a clicking noise during my dishwasher cycle. It seems to becoming from behind the access panel on the left hand side of the machine. There are...
The pump/motor assembly on these dishwashers have a soft food cutter that helps to cut up smal soft food particles. This may be your problem.
These cutter blades can sometimes get loose or something can get hung up in them like a broken piece of glass or some other pieces of trash that they can not handle.
You can access these blades by removing the sump cover near the rear of the bottom of the inside of the dishwasher. remove the bottom rack and take a couple of screws out of the sump cover. you can feel down in the sump and see if there is any trash caught up here or in the blades.
If this is not the problem and you have an older dishwasher - you could have a problem with a loose fan blade in the motor. If this is the case I would run it til it dies. The motor/pump assembly is about $125+. The newer motors are a lot quieter.
If everything is working ok. I wouldn't worry too much about it.
Aug 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Broken plate in dish washer. Pump is now making noise. How to take pump out and clean?
at the bottom rear of the dishwasher there is a cover over the sump. remove this cover and below there should be water in the sump. feel down in this area and clean out the trash. there is also a metal cutter in this area that chops up small particles of food. you could have something in this area caught. be careful not to cut yourself.
Jul 18, 2010 | GE Nautilus 24" Built-in Dishwasher
There is a kind of grinding noise.
The most common reason for a grinding noise on an LG dishwasher is debris getting stuck (rather than ground up in the build in disposal.)
To resolve, remove the approximately 9 screws on the filter assembly in the sump area. You will need to remove the lower spray arm to get the filter out. Grab the spray arm and lift up and out.
Use a flashlight to inspect the entire area, especially in the rear area that has the valve that alternated sending water from the lower spray arm to the upper spray arms. I bet you fill find something lodged in there. Please be careful of broken glass as it can be almost invisible in water that remains in the sump area.
Please post back here what you find, OK?
Aug 06, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher has power and water but rinse arms are not working
Vicky,
I understand that your LDF8812 fills with water (and drains?) but is not cleaning and you are not hearing the unit wash. Are the dishes on either rack getting wet at all?
-Are you getting any error codes in the display?
On LG dishwashers, the upper and the lower arms never spin at the same time. Rather the vario check valve routes all water pressure either up or down.
The arms turn because the wash motor turns the pump (impeller) which drives the water to/through the wash arms. If the wash motor was faulty, you almost always get an error code. So the problem is probably caused by a blockage of the "plumbing" in the sump area beneath the lower wash arms. But first check all three wash arms to confirm that the holes are not blocked. (How cool is it that the light inside this model helps you do that?)
Next use a screw driver to remove the filter assembly in the sump area. There are 10 screws to remove, but first you need to firmly lift the lower spray arm directly up and out.
Inspect the entire sump area for debris. Watch out for broken glass! Look closely at the white area near the back for blockages at the check valve.
Please report back what you find and we will take the next step. OK?
May 18, 2009 | LG LDF8812 Stainless Steel Built-in...
Heater not working in cycle. No Error Code present
The LG 5811 dishwasher would display the error "tE" if the thermistor has failed. Not seeing an error could mean that the controller card (PCB) has failed. Hard to tell if the heating element has failed or wiring has shorted.
To look a little further, you can see (but not remove) the heating element by removing the filter in the sump area beneath the bottom rack. Disconnect dishwasher from power first and inspect for obvious failure of element.
Gaining access to the heating element is very complicated on the LG units. You have to drop the entire sump unit after turning the dishwasher over on its top.
Recommend a service call.
Feb 10, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Motor removal
I am having a same problem. You can open dishwasher sump assembly from inside the dishwasher and check if something is blocking white impeller. I tried to open impeller and sheared screw head as I did't realized it is left handed screw. Even after cleaning impeller you still get problem, you need to check from bottom and see if something is stuck there. If all right and you are still getting error then it is time to replace motor. In my case I ordered entire sump assembly as my seals were also wornout. Sump assy cost $113 on Sears part direct.
Dec 30, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Bosch dishwasher model shv4800/shi6800/shu6800
you should have two filters. one you can unscrew .its a smaller round looking filter right under the bottom spray arm .once removed you just pull up on the flat filter that lying on top of the sump area
Dec 22, 2008 | Bosch 23 in. SHU303 Built-in Dishwasher
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
