Question about Kenmore Refrigerators
Freezer seems to be working fine, but the refridgerator is cool at best with the thermostat all the way down. I tried to defrost, but with no help. I think the fan in the freezer might be bad.
    Novelist:
    Champion:
  • 266 Answers
The only place that cools in a refrigerator is the freezer. The refridgerator side stills cold from the freezer via an air duct that runs from the freezer to the refridgerator. If your fan in the freezer compartment is not working your refridgerator side will not work. To replace the fan you will need to clean out the freezer including the shelving. Then remove the back panel all you need is a phillips screw driver. When the back is replaced the fan is at the top. It is held in by two screws that go threw rubber mounts on the fan braces. You will need to remove one ground wire and two electric wires on the motor its self. Make sure to unplug the refrigerator before starting the repair. good luck
Posted on Aug 29, 2010
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Sep 07, 2012 | Amana Refrigerators
The freezer works real fine, but the refridgerator will not cool down. sometimes the freezer frosts up behind the plastic barriers in back/ model fr662nb
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 22, 2011 | Daewoo Refrigerators
My kenmore elite freezer works but the refrigerator is not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 09, 2010 | Kenmore 53642 / 53644 Side by Side...
Freezer working, but refridgerator is not cold. The fan works.
You most likely have a failure in the defrost circuit. One or more of thee possibilities: Heating element, defrost timer and/or defrost thermostat.
Check these links:
http://appliancehelponline.com/defrostheatervideo.html
http://appliancehelponline.com/referdefrostheater.html
.g_thread_answer { overflow:visible !important; } X Leave your feedback for the Expert! Write a testimonial (150 Characters max) Submit Testimonial Back
Was this helpful?
Rating helps you get better solutions
Somewhat Helpful
Jun 08, 2010 | Maytag MBB2256G Bottom Freezer...
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
DEFROST SEEMS STUCK
Do you have ice at the back of the freezer section. If you do defrost the unit and see if this makes a difference to the performance. If it behaves you probably have a defrost heater or defrost thermostat fault. If it fails to pull down you possibly have a fan motor gone or a problem with the defrost circuit. I would suggest if it behaves monitor closely and if it fails contact a good fridge guy who should be able to diagnose which fault it is. Hope this is of some help.
Sep 13, 2007 | Refrigerators
Refridgerator not cool enough.
sounds like the probable cause is defrost heater. get someone to test the element.
May 27, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
234 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
