Situation:
Pixma IP 5200 r (up until now worked fine) wont let us print with the cd labeler Proggy.
Configuratoion:
Pixma is hooked up the network - to a print server (w2k3). Client Print (obviously ;) )....
Problem:
Domain Admin can Print (no problem - W2k AND WXP)
Local Admin cannot print with the cd labeler anymore on a w2k client (though he can print normally!). He can print on WXP. This problem occured when we put the print server online last week for 5 hours and back on (only thing I can think of that could have caused the problem).
Server side:
Observations on the sever side are as follows .... as soon as local admin starts a cd label print job - the cd labeler dialogboxes show up (u know -> "make sure cd is not put upside down etc!) - click ok -> next screen -> "r u sure you want to print" .... up to that screen, I see everything on the server as well. As domain admin (as soon as I say ok on the client -> the dialog box on the serverside closes down -> print job starts!)
As "normal" local admin ->pressing ok -> the dialog box stays on the server side and does not "vanish" ->you would have to click ok as well on the server side to make sure the job gets done.otherwise -> no luck!
After long research .... I found out that the pixma is indeed a network printer ;) .... BUT it has a printserver already build in!!!! Having 2 Servers is obviously not too good of an idea ;) ....still wonders me as to why it did work in the 1st place ..... (i guess there was something wrong with the w2k3 print server *muhaahha)
Hi My printer is not taking paper and it seems the roller that feeds is not working. the light...
(More)
Hi My printer is not taking paper and it seems the roller that feeds is not working. the light flashes 11x which I saw means 'ap position error' does anyone know if this can be repaired? Or how? Many thanks,
Pixma ip5200 has mail lable wrapped around roller and is printing white streaks on printouts. How to...
(More)
Pixma ip5200 has mail lable wrapped around roller and is printing white streaks on printouts. How to remove and clean or replace roller?
I have just changed the ink cartridges but the printer is not used for quite some time. After it is...
(More)
I have just changed the ink cartridges but the printer is not used for quite some time. After it is switched on, all seems normal except that the printer can't form feed the paper to print. The papers are placed properly and print job is in order, but even I have reset the printer a few times, it still does not print. Please advise the solution. Thanks.
Whe I try to open the CD Lable print program this message appears in a box on the screen I used it...
(More)
Whe I try to open the CD Lable print program this message appears in a box on the screen I used it Yesterday morning without any trouble suddenly it hangs up after I used Task Manger to quit the program I restart my computer re-install the printer drivers etc but is still appears when I'm trying t locate the program to print on the CD's please I'm stying in Sout Africa. nicolene.heydenrych@gmail.com
I have a Canon Pixma iP5200R which has been going great up and until now! Now the print outs are...
(More)
I have a Canon Pixma iP5200R which has been going great up and until now! Now the print outs are coming out in colour but with purple tinge. Checked all cartridges - switched off computer and printer and restarted. This solved it for about 5 print outs, now it is back. Why?
