My computer pops up virtual memory low What dos this mean and what should I do?
    Sergeant:
  • 201 Answers
If your system is running sluggish.its possible your in need of a fresh set of windows.first though try defragmenting your system.also have a look at your memory spec.its possible it needs beefing up .you can check this by going to cnet download a program called cuipd or cpu-z. this will tell you how much memory resides in your system. www.askdavetaylor.com/how_can_i_fix_too_little_virtual_memory_in_windows.html finaly go to this site for the rest of your possible probs .hope this helps.
Posted on Aug 28, 2010
Every time I start my computer, a message pops up: "Low Memory." How do I fix this. Thanks.
Check for the hard drive space where the operating system is installed, normally this message comes when the space is low and windows is not able to create virtual memory required to run windows.
Aug 05, 2010 | Computers & Internet
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
Blue screen & A message pop-up on my ToshibaSatellite A105-S4011:
try removing some unwanted programs. run disk cleanup, then defrag
Apr 04, 2010 | Toshiba Satellite A105-S4011 Notebook
Low virtual memory and slow loading
Go back into the virtual memory settings, change the settings using the custom size adjustment.
Change the initial size to 650 and the maximum size to 1200, make sure nothig else is checked and click set and then ok and exit out of all windows and reboot the mechine. let me know what happens and if the bubble popup disapears. cheers.
Mar 25, 2010 | Computers & Internet
Virtual memory too low
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Advanced tab.
  3. In the Performance pane, click Settings.
  4. In the Performance Options dialog box, click the Advanced tab.
  5. In the Virtual memory pane, click Change.
  6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
  7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
I hope this helps you with your issue. Don't forget to rate. Have a great day!
Feb 26, 2010 | Acer Computers & Internet
The instruction at "0x012cf496" referenced memory at "0x012cf496"
you should increase the virtual memory of system,to increase the virtual memory :-
->right click on my computer goto to properties tab
->then goto advanced tab
->performance setting
->advanced tab
->virtual memory
now increase the virtual memory with current
OR
:>type chkdsk command in dos
Jan 15, 2010 | Microsoft Windows XP Professional SP2 for...
Low virtual memory problem
your computer has used up its physical memory (RAM) and is currently utilizing and eating up hard drive space. A computer designates a certain amout of "FAKE" or wat they call virtual memory from the hard drive and when that is taken up it shows low virtual memory. Simply put this just means you need to increase the amount of ram on the computer :)
Mar 22, 2009 | Dell Dimension 2400 PC Desktop
An error pops up everytime we log on to the internet
what it means is it is a popup and the computer is trying to block it but cannot and so the popup is trying to gain acsess to your computer via the internet/a webpage. that is all i know i sorry i hope this helps.
Feb 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
My vitual memory
it means the amount of hard drive free space is either low or it means you must increase the limit of this space. first remove any un-necessary files by doing the following: 1.) open explorer and click c drive. 2.) right click and select properties 3.) select "disk cleanup" now select the Tools tab above and select "check now" now select "Defragment now" next, right click "my computer" on desktop then select Advanced tab and select "settings" then select next Advanced tab and select "change" in the virtual memory area. type in the maximum under custom size and select "set" and ok out.
Sep 15, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
David Payne
David Payne
