Question about Dishwashers
Bought a used Maytag dishwasher Series 100 - there are 2 wires black and white. How do we plug it in?
  • Dishwashers Master
  • 43,501 Answers
Hook the two balcks to the balck coming in and the white to the white coming in...
heatman101
Posted on Aug 29, 2010
Amana DW adb1100aww New install won't start
have you checked to see if the white and black (or hot) wires are reversed.
It is very common to have this problem.
some plug wires have a smooth edge and a rippled side, one wire per side and the ground wire is green or in the middle.
if there is a side that has a rippled edge make sure that it is on the black wire of the dishwasher and the white to the smooth side.
I remember this in this way: if i hook the power side to an oscilloscope it would show a wave pattern and if I do the same with the common or white wire then it is smooth a straight line
Apr 18, 2014 | Amana ADB1100AWW 24" White Built-In...
Where on dishwasher is power supply? like how do we connect to power?
You connect your incoming 120v supply to the black and white wires on your d/w. the black and white wires are located at the bottom of your d/w on the right hand side in a small box. You may need 1/4in nut driver to open the box and there you will find your white(neutral) and black(hot power) wires located
thanks.
Dec 12, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
My Maytag Quiet Series 100 is leaving a white residue on dishes and glasses. The problem seems to be getting worse. I have used multiple dishwasher cleaning solutions, with no resolution to the problem. ...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 | Dishwashers
Maytag series 100 dishwasher not completely emptying after cycle
I am having trouble with water not emptying out of dishwasher completely help
Jan 07, 2010 | Maytag Dishwashers
I lost my manual and i can't fiqure out how to connect the dishwasher. i see the light that shows what to wash but the power buttom is not on
When you say connect, I assume you mean you are installing or reinstalling a dishwasher. With the power off, you always connect the black wire with the black wire on the dihswasher. This is the HOT or the LINE wire. The white wire hooks to the white which is the COMMON wire, and the bare copper wire connects to the green screw or green wire and is the GROUND. If you are using a pig tail (plug in connection) the common wire will usually have a line or series of lines going the length of the wire. Just be sure you identify the correct wire because a dishwasher will run with the hot and the common connected backwards which can create a dangerous situation if a short develops inside the dishwasher. Use wire nuts twisted on snugly and enclose all wiring connections in the connection box. Hope this helps! Ken
May 03, 2009 | GE Dishwashers
Electrical for dishwasher insallation-missing wires?
black wire is phase,white is 0,you need single phase
pork for this wire if it is on devices.
Feb 17, 2009 | Dishwashers
Broken handle on dishwasher
Bernie,
TURN OFF POWER TO UNIT. Open door, remove all torq screws from door panel, separate inner and outer door panel. latch assy is able to be removed, place black wire connector and white white connector back respectively, place inner part of door back and replace the torq screws. Then turn power back on for unit.
Jan 09, 2009 | Maytag Dishwashers
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dishwashers Logo
Top Dishwashers Experts
