Question about Peg Perego John Deere Gator HPX
My Peg Perego Gator will drive for a few feet then stop, repeatedly doing this. I've replaced the battery but that does not seem to be the issue. Does anyone have any other suggestions?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Sounds like a bad motor, you can get a new one here www.powerwheelsoutlet.com
Posted on Jun 08, 2012
momsjustknow
  • 135 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 156 Answers
SOURCE: peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
  • 29 Answers
SOURCE: Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Posted on Apr 20, 2010
Peg pergo John Deere Gator goes for about 2 seconds then stops suddenly
it almost sounds like a thermal fuse, but these don't have a thermal fuse, so id say it might be a bad shifter switch
Dec 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
I have a Peg Perego gator. Battery seems to still have power, but it does not run. As some point, it seemed to "Stutter". It would catch and run, but then suddenly stop. What could it be, and...
Do you hear a clicking noise when it stops working? also maybe hook the battery up to a multimeter and then wiggle the wires and see if the voltage drops
Aug 18, 2011 | Peg Perego John Deere Gator HPX Ride on...
Our son's peg perego john deere gator stopped working and we thought it was the battery so we bought a new battery. We charged the new battery for 24 hours and hooked it up to the gator but it still gave...
It is most likely the Gearbox, it is easy to find and easy to replace. It is right under the gear shifter and is a "harness" with wires that will need replaced, if you call the tech support for Peg Perego they are very helpful and will get you on the right track. Your old battery is most likely fine, but keep it until you fix the gearbox switch. Afterward (when gator is again operational) I would imagine you could return the new battery since you really should not need it. Peg Perego support is 1800-728-2108 and you can also look for parts at www.mypegperegoparts.com
Feb 19, 2011 | Peg Perego John Deere Gator HPX Ride on...
Gator works on and off
I replaced the shifter with the peg perego upgraded shifter and that seemed to fix the problem, but you can contact the repair department at
http://www.mypegperegoparts.com/ and they will be able to help you
hope this helps
May 26, 2010 | Peg Perego John Deere Gator HPX Ride on...
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Gator- goes a few feet & then cuts out.
It sounds like the thermal fuse is being kicked on under the shifter. The wires might be loose on the motors in the back, or the motors themselves are getting hot causing the fuse to trip.
The gator as a specific peg perego shifter assembly that has been upgraded with the wiring as well.
I would contact the guys at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html I have a few of these toys and these guys have always been helpful. Hope this helps
Apr 29, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
