Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Kenmore Oven Mod# 665.75012104
The oven works sometimes, the igniter clicks four times but nothing happens. If you get lucky it may light the first time but not relight during a cycle. The broiler works fine as well as the stove top. Please help got a graduation party Sunday.
  • 943 Answers
Hi. thanks for the question .i would replace the bake igniter. that will solve your problem. happy graduation .thanks the appliance doc
Posted on Oct 02, 2008
Kenmore Oven- The oven doesnt heat or light at all. If I sent it to 350 degrees; should i still smell gas?
I beleive this model has an electric igniter, You may have to change this they sometimes just wear out, or it's just simply your pilot light is out and you need to relight it, hope this helps.
Sep 19, 2012 | Kenmore Ovens
Oven takes a long time to light.sometimes lights after stove top burner is lit first.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Apr 20, 2011 | Kenmore Ovens
Why does the Oven take so long to light?
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stop glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Nov 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore gas oven won't light. The pilot light is on but no gas. What do I do?
Put a torch on the probe. If the flame comes on them the thermocouple is weak.If nothing at all replace the safety valve.That is if you have a standing pilot. If you pilot is an electric one then it should be so bright it is hard to look at but if it is dim orange it is weak.
Sep 07, 2009 | Kenmore 30169 Electric Single Oven
Kenmore gas range model# 362.72321 Oven will not ignite (sometimes)
Range Oven Temperature Sensor Part Number WB20K0004 Sears PartsDirect
This will be why the oven acts up. The broiler doesn't rely as much on this as the bake part does. Replace this and it should fix your problem.
Jun 14, 2017 | Ovens
Kenmore Gas Range
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Jul 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven won't light
Jun 23, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
162 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
