Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
Top agitator will not turn bottom agitator turns
Top agitator will not turn bottom one half will work
Posted on Oct 22, 2010
SOURCE: Won't agitate!
you should try to stop sticking the agitator up your *** so much =)
Posted on Apr 16, 2008
larryyb
  • 291 Answers
SOURCE: agitator will not turn
yes ,,, they are called agit dogs ,,,,, replace and that will fix it
Posted on Nov 24, 2008
jsrock516
  • 5911 Answers
SOURCE: Agitator top is not engaged to the bottom part
This problem is generally caused by worn agitator dogs which are part of the agitator cam under the top portion. The dogs act as a clutch to drive the upper portion of the agitator. The do wear out with age and require periodic replacement. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a very simple problem that can easily be repaired by the average do-it-yourselfer for very little money. Replacement parts can be purchased on line at searpspartsdirect.com. Just type in your model number and look under the "Agitator, Basket and Tub Parts" heading for item number 10. For a little more, the entire cam replacement kit (which includes the dogs) can be purchased as item number 9. If you do not wish to purchase on line, take the part numbers listed on the website and go to your nearest appliance parts retailer. These parts are commonly part of their in store inventory.
Read through the link thoroughly and let me know if you have any questions. I hope this helps you.
Posted on Jan 18, 2009
  • 54 Answers
SOURCE: Top part of agitator won't agitator
You all have a problem with a part called agitator dog.. 4 little hard rubber like pieces that goes in the top agitator.. and yes washing blankets or overload can cause this..pop top cap and you will see a bolt that holds the agitator..remove that and take out agitator.. and replace agitator dogs ( comes in a pack of 4).. make sure they all face same direction... good luck..
Posted on Jan 21, 2009
WRMtech
  • 70 Answers
SOURCE: top half of agitator turns free (does not agitate)
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Posted on Feb 26, 2009
The agitator is not working properly. The top is not turning just the bottom section is working properly.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
May 29, 2010 | Kenmore Washing Machines
Agitator doesn't turn
Apr 21, 2010 | Kenmore 24032\24036 Top Load Washer
Model 110.29852991 top 1/2 of agidator doesn't turn. the bottom half does turn.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.29852991&pathTaken=partSearch
Mar 27, 2010 | Kenmore Washing Machines
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Series 80 Agitator top dosent work
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Following is an illustrated description of the above.
Jan 09, 2010 | Kenmore Washing Machines
Agitator not working properly...lower part works while the upper part just sits there not turning
you nead to replace the dogs in the top portion of the agitator.first remove the fabric soffiner despencer from the top of the agitator,next there may be a plactice cover that you nead to remove,next you nead to remove the 7/16 bolt and pull up on the bottom of the agitator and remove the agitator and place it on the floor,put a foot on both sides of the bottom of the agitator,next you nead to grab the top of the agitator and pull up and remove the top of the agitator.place your hand inside the top of the agitator and turn it upside down and remove the dog assembly.replace the rubber dogs and reassemble the agitator and reinstall the agitator.
Dec 31, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Top agitator won't rotate. bottom rotates but top is stuck in neutral and spins freely
Also see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=a10ed20760ebb48ebf7c5df88d5f840d
Nov 21, 2009 | Kenmore Washing Machines
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
I have a kenmore elite model # 20949 and the bottom of the agitator turns but not the top
direction only.
Oct 31, 2009 | Kenmore Washing Machines
Agitator: bottom moves, top does not
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
