Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite He4 washing mashing. What is error code "dLF" or "FdL" and how do I fix it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error “dlf” or "F dl"means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    GIVING CODE FDL?
    If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
    Jan 22, 2011 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite he4 quiet pak 9 dryer display code
    PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    May 15, 2010 | Kenmore Elite HE4 Electric Dryer
    What does code FDL mean? kenmore elite wash maching
    You are getting and error code F-DL which means the main control board is sensing that the door is not locking. Most likely a problem with the door lock/latch assembly.
    Feb 02, 2010 | Kenmore 45981 Washer
    FDL fault code on kenmore elite washer
    F DL
    A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
    Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
    Error code dL F is popping up on washer. Door will not open, is locked but light will not come on on panel where is says "door locked." Can't wash, nor get the clothes out that need to be washed.
    Fdl is a code that indicates a door lock error. This error occurs because the washer senses that the door cannot be locked (even if it is). The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
    Sep 01, 2009 | Kenmore Elite HE4 Electric Dryer
    DLF error code. What does that mean?
    DLF probably means Door Latch Fault.
    Jun 22, 2017 | Washing Machines
    Kenmore Elite HE3 washer won't spin during rinse cycle...
    possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
    Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
    Kenmore elite he3 - door lock
    If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
    Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    726 people viewed this question
    Sal DeAngelo
    fordexpert
     Brian Main
    Brian Main
