Question about Whirlpool Washing Machines
Agitator won't come apart so I can replace the dog ears
FixinFax
  • 3085 Answers
SOURCE: I have whirpool LSQ9549LWO agitator will not come
I know this is a tough job. Try dripping something like liquid wrench down inside and tap with a wooden block.
Posted on Sep 09, 2009
Testimonial: "Thanks for the help that did the job"
jsrock516
  • 5911 Answers
SOURCE: cant seperate the 2 pieces of my whirlpool ultimate care 2 agitator mod. lsq9544kocq
The following link should help you with removing the agitator to replace the dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Whirlpool models generally only have two methods of removing the agitator. One type uses a hex bolt, and the other uses a recessed square nut. The removal procedures are explained in the link provided. I hope this helps you. Please let me know if still have questions.
Posted on Oct 26, 2008
duby1990
  • 370 Answers
SOURCE: not agitating
Check your drive coupler. Its the rubber piece between the motor and the transmission which makes the washer agitate and spin. the easiest way to check it is to lean the machine back and look for rubber on the floor. Then look behind the motor to see if it is still in tact. Next try wiggling it, If it wiggles a lot replace it. If that doesnt fix your problem, you probably have a bad transmission.
Posted on Nov 18, 2008
aborcass
  • 2651 Answers
SOURCE: Agitator mover won't seperate from agitator
set it on the floor step on both ends,( turn your head( dont want to hit yourself in chin) and PULLL
Posted on Mar 17, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore agitator clutch dog replacemant?
The followng link explans how to replace the agitator dogs:
Read through the instructions and let me know if you have any questions. I hope you find this information helpful.
Posted on Jul 07, 2009
Agitator not working but spinner is fine how can i fix myself?
the dog ears are wore out look at a vid on it type in dog ear re[placement washer perhaps that will lead you to one if you open the washer the center top of the agitator pull off the cap there should be a bolt head down there unscrew it and pull out the top area the dog ears will be there three little plastic thing looking like teardrops with small fins to catch the agitator to move it they are worn out cheap to replace
May 14, 2016 | Washing Machines
Replacing agitator dog ears
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST.
We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you get your appliance problems resolved soon.
Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator does not work washer goes through all the cycles it just dos not agitate model number 110.28732700 SN: CW2040704
your agitator dog ears are worn, can get some from your nearby appliance shop or order from Repairclinic.com,,,,,not hard to replace,just pop cap off with a screwdriver then with a 7/16 socket ,ratchet and extension remove the bolt in top of agitator then lift out the dog ear assembly and replace,be sure to look at the grooves your dog ears lock onto see if they are bad
Feb 16, 2010 | Kenmore Washing Machines
Agitator wont go, have taken apart and believe the plastic teeth are all gone, how do we replace that and what is that part called
if your talking about the little dog ears at the top of your agitator under the cap ,those are easy to replace , they are called DOG EARS can get from your appliance shop or order from REPAIRCLINIC.COM
Feb 14, 2010 | Washing Machines
Agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Jan 11, 2010 | Maytag Washing Machines
Agitator top portion not working
You need dog ears for your agitator. They cost about 50 cents and are in stock at most appliance parts stores. Tor replace them remove the top cover from the agitator. Uncer the cover there till be a bolt to take the agitator off. They are 4 pieces of plastic that resemble dog ears and lock your agitator in one direction while allowing it to spin in the other.
Oct 25, 2009 | Washing Machines
Need to get the agitator off
that's funny [feed dogs]they are called, dog ears but you do now have to feed the dogs because their not working.lol.hey you will have to get those parts on-line or at an appliance store.lowes wont carry those that i know.anyway if you pop the cap of the agitator you will see a piece that has a small handle.pull up and remove that piece.then you will see the bolt to remove to pull the agaitator[its a 7/16]take a good look at how its together before you take apart.......ok now that the agitator is out place on floor,put feet on the bottom piece and pull up on the top piece til comes off.then dump out the piece in the top w/dog ears in it........install new ears in that piece and reinstall upside down,inthe top piece of the agitator.then apply pressure on the dog ear retainer and place over the bottom piece of the agitate aligning the two little tabs sticking up on the bottom piece of the agitator with the little cut outs in the dog ear retainer....now take your socket to place bolt back on,put some plastic wrapper or package from dogs in the socket and push the bolt into it.then place the bolt in the hole of the dog ear retainer .now lift agitator up and place onto transmission shaft and tighten bolt and place cover back on................boy that was a lot of words.that should do it for you God bless you Tiffany ,from tom
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Cant seperate the 2 pieces of my whirlpool ultimate care 2 agitator mod. lsq9544kocq
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
We have a modle # LLR7144DQ0 - the agitator is not working properly. It is not pulling the clothes down into the water.
The agitator 'dog ears' have worn out. Very easy to replace.
  • Remove fabric softener or protective cap on top of agitator
  • Remove center bolt securing agitator.
  • Lift out agitator and replace dog ears.
Jun 23, 2008 | Whirlpool Washing Machines
Agitator won't spin back and forth like its stripped
I think what you have going here is some worn agitating ears. In the appliance world we call them dog ears. You have to remove the fabric desp, it should just pop off. Under there will be a cap that you can grab with a needle nose pliers and pull the cap off. Now you will be looking at the bolt that holds the agitator to the shaft. Remove this bolt and you can get to the dog ears and plastic bearing. There is a kit for this and the part number is 3951682. This is not a hard fix...just take your time and observe. Catriver...post back.
Jul 29, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
199 people viewed this question
Dan Webster
Dan Webster
Sal De
