Question about Bosch 4000 - 07 Electric Table Saws
My table saw was overheated and now will only run in reverse?
  • 2,176 Answers
Sounds like you have a major electrical problem possibly, when it overheated did you get a burning smell from it and if so it could have burnt up the field and or armature. If you are comfortable with disassembly let me know and I will try and help
Posted on Aug 30, 2010
I would like to reverse the rotation of a 60-042 delta TEFC 1 1/2 hp motor. any suggestions? Need CW rotation for a table saw
have you got the saw blade on the right direction for cutting
all motors run in the right direction if the blade is on right
Jan 27, 2017 | Delta Saws
How do i replace brushes on dewalt table saw
unscrew brush cap on each side of motor and pull brush out
do it reverse with new one
Sep 07, 2012 | Dewalt Saws
I am trying to get the saw blade off. Is it reverse threads? Thanks, Jerome
Yes is is reverse threads. If you put a block of wood in front of the saw blade and wedge it against the table, you can put your wrench on the nut and pull towards you assuming you are in the front of the saw where the switch is.
Apr 22, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Band saw is going in reverse how to i fix that
The motor is AC (alternating current) and only runs in one direction. Therefore, the only way to reverse the saw blade direction is to flip the position of the motor 180 degrees. The teeth of the blade should be pointing down and face to the left when you are standing in front of the saw. The blade should travel down into the table so the blade pushes the work into the table. I hope this helps since it sounds like the blade may be installed incorrectly.
Mar 22, 2011 | Wilton 14in Woodmetal Cutting Band Saw
My table saw runs in reverse when turned on it is a 4000
This is unfortunatly a fairly common problem with the Bosch saws, the field coil has failed and needs to be replaced. If the saw is less than a year old it will be under warranty, if not this repair is still worth doing as it is alot less than a new saw. This repair is faily difficult and should be done by a Bosch service center, find one in your area and they will be able to help you.
Jan 01, 2011 | Bosch 4000 - 07 Electric Table Saws
I was cutting 2" dense foam insulation board,
The problem you have is a faulty field coil, the Bosch saws unfortunatly have a bit of an issue with this. The coil can be replaced separatly so you won't have to replace the whole motor. Bosch has a 1 yr warranty on thier table saw so this is a warranty replacment provided the saw was purchased within the year. If not the coil replacment is still cheaper than buying a whole new saw, but should really be done by a service center because of the level of difficulty of the repair.
Nov 10, 2010 | Bosch 4100 10" Worksite Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
I can't get the rip fence on my bosch 4000 table saw to square up to the table. the fence is parallel to the blade but when locked down it tilts a hair towards the blade at the top. and it doesn't seem...
hi ,
this is the link to the bosch manual for your table saw , it has the assembly instructions ( just reverse them ) and full details of the alignment proceadures required to true the blade/guides and fences up .
http://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D/t10/0000000/r00160v-1.pdf
hope this helps
Jan 17, 2010 | Bosch 4000 - 07 Electric Table Saws
Miter saw motor is running back wards
I'd say it was the new wiring that was reversed. Motors cant really start reversing themselves on their own and the only other way it would seem reversed is if the blade was put on backwards...
So yes I think you have the wires reversed when you re-wired the cord.
Please rate this solution on FixYa!
Jun 21, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Bosch 4000 - 07 Electric Table Saws Logo
89 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
