Question about Splendide 6200
Dial contin ues moving and will not complete it cycle full of water and wont drain please help
  • 3 Answers
MAKE SURE YOU CAN COLLECT THE WATER AND WILL NOT DAMAGE ANYTHING BEFORE YOU DO THE FOLLOWING! In the front bottom right, is a water plug. unscrew it. water will drain. check if debis in there and look at impeller. The reason why the dial spins, is because it is giving you a fault code. count the number of the red light blinks. i have the diagnostic manual that has the fault codes that shows how to check components with an OHM meter
Posted on Nov 24, 2012
  • 183 Answers
SOURCE: whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Posted on Jul 30, 2007
natengel
  • 19 Answers
SOURCE: Washer stopped in mid-cycle and is full of water. I can restart the cycle, but
if it stops at #6 u need to change timer and motor
Posted on Oct 31, 2007
SOURCE: Washing machine will not drain
Will the water in tub come out when you take off the hose?
Posted on Mar 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
Posted on May 13, 2009
SOURCE: water not draining away after cycle
Hello Friend,
It seems like your machine is neither Pumping nor spinning, that is why it is unable to drain the water out. In this case you should check the pump. Your washer probably has a frozen pump pulley. If so you need to replace it. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Give it a check. Do get back to us if you need any further assistance.
Thanks
Posted on Mar 05, 2010
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
Hotpoint washer fills begins to agitate then refills continously.
Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
Dec 31, 2008 | Hotpoint VBSR3100GWW Top Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Please fill your washer with a very small amount of water, turn it to spin and tilt it back. You should be able to see the belt on the bottom turning your pump. I ask you to verify this because imporper belt tension or a bad thrust bearing can keep it from turning improperly. If it turns freely on this test, Then you have something plugged up. Drain the water out. Next unhook the hose that goes between the tub and the pump at the tub side. You can get sock or other small articals of clothing in there that will prevent draining. If that is clear. It is likely you have had another coin go through your hose that goes between the pump and the wall. They can get quite a ways in there and maytag hoses get smaller right before they end. If you have a coin in this area you will need to work it all of the way back to the pump side of the hose.
Jun 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Wont complete final spin and drain
Ok you need another repair man this is a simple timer problem since you said dial I take it as timer machine if so it has a dead spot in that cycle. although if it is a electronic control replace the control board and this will be the cure good luck and Merry Christmas
Dec 21, 2007 | Maytag MAV7600 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
May 07, 2006 | Indesit W 123 Front Load Washer
Splendide 6200 Logo
116 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
