Question about Dryers
Frigidare Electric Dryer makes tumbling noise
  • 2 more comments
  • jackson3674 Dec 05, 2008
    YES MY DRYER HAVE BEEN MAKING FUNNY NOISES LIKE SOMETHING IS BEHIND THE DRUM IS THAT POSSIBLE?
  • gsaeidian Jan 05, 2009
    feq332es
  • Anonymous Jan 10, 2009
    it is making srceaming noise
  • Anonymous Jan 25, 2009
    same problem habilusman's having
    Genius:
  • 1,073 Answers
Whar is the model number
Posted on May 07, 2008
2 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: how do you replace the
The fuses or breaker is located in your homes fusebox. An electric dryer requires 240 volts and 2-30amp fuses, or 1-30amp breaker. Locate your fusebox and determine if you have fuses or breakers. If fuses, then I recommend changing both 30 amp fuses to eliminate any possibility of being wrong. If it uses a breaker,(If not labled, look for the number 30 on a breaker). Flip the breaker to the OFF position, then back to the ON position. Repeat this action if there are more than 1-30 amp breakers and your dryer still doesn't heat.
Posted on May 26, 2008
Making a squlling noise while drying
have you checked the belt drive? Belt may need adjusting or replacement.
Jul 27, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Dryer making aweful noise
it has a felt bearing in the front of the dryer on the door the drum rides on and it is probably bad if it is a scraping and squeeling noise
Mar 20, 2014 | Frigidaire GLER642A Electric Dryer
I have a GE electric dryer and it makes a horrible screeching noise when tumbling. it tumbles and gets hot but when trying to manually turn the drum it gives me some resistance. whats the making this...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Dryers
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer is making a loud noise when tumbling the clothes. It is heating up okay
heatman101
hfgh
Feb 02, 2010 | Maytag Neptune MDE4000 Electric Dryer
GE Dryer makes deep sounds when hot and tumbling
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
My dryer -model FER311F makes a thumping noise while in use.
Check the 4 feet & make sure top of of appliance is level. These 4 feet will have threaded adjustments, just tilt the dryer back and should be able to turn with your hand or may require pliers, good luck.
Jan 21, 2009 | Frigidaire FEQ332E Electric Dryer
Maytag electric dryer model #MDE 4916AYW
If your hearing a buzzing noise, motor.. If it sounds like the motor is running, could be a belt.
Jan 07, 2008 | Dryers
Dryers Logo
268 people viewed this question
Top Dryers Experts
