I just had my hd replaced in my computer, and can't find my cd anywhere...Maxter one touch 111, 320 gig.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
The configuration for one or both drives may not be correct following the installation. You can access the drive manufacturer sites for configuration info; ie, the master/slave settings have to be correct, and also the way the drive cables are connected.
Posted on Aug 29, 2010
Can't install Alley 19 on XP.Says not enough hd space (has 31.9 Gbites freespace)Install only takes 38 mbites
Run in windows 95 compatability mode. Click on My Computer->right click on the cd drive->open-right click on setup->properties->compatability tab->choose windows 95 then run it.
May 12, 2012 | Masque Publishing Alley 19 Bowling
My dual core motherboard crashed i am trying to use the 320 gig hardrive with vista os system on this computer. Its all plugged in right i just can seem to help my computer find it. Do i have to disable...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
Jun 01, 2011 | MSI 661FM3-V Motherboard
How to add a new harddisk to a Gateway Peninum 3 550MHz machine and install win98?
Do you want to replaced the main HD or add a new one? If you want to replace the main one, buy a Hard drive under 160 gigs. I cant remember but 98 can not deal with a bigger one, you will have to cut it up or Partition it. Partition it down to 20 gig each. Do you have your Org. win 98 install disk? Get a setup program with the HD you buy. That program should let you Partition it and also format it to use with 98 or fat32. Once installed in the computer set the HD to master with switches located on the drive (small jumpers) As it boots up look for press DEL to enter setup. Get into the BIOS program and ck to see it it will locate your new hard drive you might have to set heads and scetors so make a note of the stamped on the drive. Once the BIOS has found the drive it is a matter of format w/ copy the command comm program from win98 you will have to have a good win 98 set up disk. Once you have formated the drive with fat32 and copied commamd.com you will need to install CD/Rom drivers you might have to find a good old win98 starup disk to boot up the cd. you might find a good old floppy with a cd intall on it at a local computer shop. if using an old win98 startup disk you can then put in the cd and at the Prompt type in cd win98 then type in  setup and that should be a good start.
Oct 23, 2009 | Gateway computers9: Pentium 3 Computer...
All of a sudden my mini mac does not see the external 600g one touch Maxter hard drive and it is clicking??? What is the prob??
Hi there, dont know if you have access to any other computer but if you have one solution would be to plug it in to another pc or mac to see if it does the same as it wont hurt....if it does then fear the worst....the drive may have failed..sorry
Dec 13, 2008 | Computers & Internet
Acer 2.4 upgraded to 2 gig ram and 360 gig HD. Old 40 gig HD left in place and computer is very slow
Go to start .... then my computer.... right click on my computer and select properties. on the general page does it show that it has recognized all the memory you have installed ?
Robert
Aug 29, 2008 | Acer Computers & Internet
P5ne-sli
Try with only one RAM & isolate the problem
try with different slots
Aug 06, 2008 | ASUS P5N-E SLI Motherboard
Seagate 500 gig HD found in bios but not in my computer
Once windows has been updated to SP2 & all it's updates, than windows should show the correct drive size.
Mike
Jun 26, 2008 | ASUS P5RD1-VM Motherboard
Internal hd ata
If I am right on this one the 4600 can only take a 250gig hd But I was wondering if you could partion the HD to 236.7 gigs twice so the computer only recognizes the 236.7 gig hd you will see two drives in my computer once you do just format both partitions unless you have another hd and then you will see three drives just do the ones you installed or you may loose your operating system, I don't even know if that will work, but I think it is worth a try seems you already have the 500gig drive, can't hurt to try, I sure hope this help some what.,
Dec 22, 2007 | Dell Dimension 4600 PC Desktop
PC won't boot on customn built machine
Sounds your motherboard is gone, my solution to you is to remove the hard drive, place it on another computer as a secondary drive or slave and go into my computer and you will see your hard drive there as secondary ,, now you can go in to it and save your data to a disk or do a back up onto a cd. please advice.
Sep 23, 2007 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
