Question about Dell Computers & Internet
This is Joseph, I have Dell Inspiron 1474. What happened was I forgot to unplug the charger while doin' my stuff and fell asleep. When I woke up, the screen went black and when I restart it never proceed to Windows 7. What seems to be the problem, please help. Thanks
acdr
  • 1913 Answers
SOURCE: NO VIDEO ON DELL INSPIRON 1501!!! PLS HELP ME!!!
ok
when u power up the paltop press F8 key then go to last known good configuratuion if probelm remains same then chosse safe mode then remove your network driver from it.
also try to rest your defauls sdetting in bios .
when u power yup the laptop press del or F2 or F5 to F12 try this key one by one.
then go to load defauls settitngs then save that settings.
also check in enable vga mode when u press F8 key at power up.go to enable vga mode tthen settings of disaply porperties.800*600 or 1024 *768.
Posted on Nov 10, 2008
SOURCE: blank screen on a Dell Inspiron 1501
Here's how to work around the problem with the screen going blank when the A/C power adapter is attached.
With the battery only connected increase the screen brigtness using the blue Fn (function) key and the up arrow until you start to see the screen flickering. Now use the function key and the down arrow to decrease the screen brightness until the flickering stops. Plug in your A/C adapter and if the screen brigness increases, quickly bring it back down to the level where the screen does not flicker. It should continue run at this reduced brightness level.
You can then go into the the BIOS setup during the boot up sequence by pressing F2 and set this reduced brightness level so that any time you connect the A/C the brightness will automatically be set to the lower setting that avoids the problem.
Posted on Jun 27, 2009
KingDWS
  • 1606 Answers
SOURCE: dell inspiron 1420 startup error
You need to cheat a little. First try to boot into safe mode by pressing the f8 key as soon as you hit the power (and keeping your fingers crossed on the other hand that it notices your doing this). Before you get too depressed just try booting into safe mode and then reboot normally. That may be all it take to fix it. Try this a few times before getting into the more serious fixes.
If you can get into safe mode you can simply copy your files off to a usb data drive. Those will still work. You may be able to use the wired network card if you select safe mode with network access. But don't count on that. The cd/dvd will not work so you can't burn it to disk. A flash drive will work on the usb while a external hard drive that connect via usb usually won't as it needs drivers.
The other way is to boot using a bootable cd. If you can get a vista install cd you can install over the top of your existing windows and retain your settings. If you don't know where everything is then you need to be a bit creative and use something like the demo Ubuntu cd that boots into a windows like operating system that will allow you to copy stuff over the network to the usb drive or the network.
If you have a friend with the right laptop or desktop you can take the drive out and set it up as a second drive. When they boot normally they then can see your drive and just copy burn or move your stuff. This is what I do in the shop when the existing system is too messed up to work with. There may be the odd thing you won't get access to but you should get most of it.
Posted on Jul 09, 2009
  • 56 Answers
SOURCE: had it on fell asleep woke up would not power up
can u expand yo problem thn we can help u,but u can try to remove the battery thn put it bk i thing it will be fine
Posted on Aug 14, 2009
  • 43 Answers
SOURCE: BOOTMGR is missing? dell inspiron e1705
any way u hve to get windows 7 disc and u will have to repair it.
Posted on Sep 01, 2009
My dell inspiron won't charge if the OS is awake/on but DOES charge when it's off/asleep. this is a new problem.
This appears to be a common problem. Sounds like the current is not being shared while in use. If you know the battery to be good, I'd check the output voltage of the charger 1st and see it is putting out the right voltage. The chargers for the Mini series are weird, so may be worthwhile borrowing another charger to eliminate it from the problems.
After that... you may need to get the laptop checked by Dell
Jun 15, 2011 | Dell Inspiron Mini 10 Notebook
Fell asleep with my rca projection tv on woke up to no picture But sound. I turned the tv off and unplugged and now when I turn it on I can here it powered up but no picture or sound. The power button...
Look for bad capaciotrs on the deflection board cp150 2200uf 16v use 25v(,cp114,cp120) bothe 220uf 35v,cp110 220uf 200v. Deflection board is the bottom lefthand side board that has FBT flyback Transfomer on it also resolder all the Pinns on the FBT.
Dec 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Inspiron 8500 wont load completly it turns on and when it has finish loading halfway it shuts off. I tried presing F2 and F12 but it still shuts off. This started happening after i fell asleep on it...
It sounds like overheating. I would check the fans in the back to see if they are packed with lint. You will need new thermal paste, then take the keyboard bezel off then remove the screws that hold down the keyboard. Remove the four screws over the heatsink and then remove the fan. Blow these out, make sure there is nothing in the vents or heatsink. Use a credit card to scrape off old thermal paste on the processor, and the heatsink and put a small amount on the processor and put it back together.
Jul 11, 2010 | Dell Inspiron 8500 Notebook
The on light is blinking but there is no picture or sound.
I have the same problem with my JVC AV27750, the problem is probably the power supply relay circuit, just check and replace the 1000uf capacitor
Jul 06, 2009 | JVC AV-36260 TV
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Dan
Feb 24, 2009 | Sanyo DS31590 31" TV
LOCKED BRIEF CAN'T OPEN
I am unsure what your question is
RCF
Sep 03, 2008 | Microsoft Office Xp Professional Full...
Computers & Internet Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
