Question about Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch
My bezel is scratched. Any idea where to get a replacement or is it just as easy to go out and buy a new one?
    Genius:
  • 1,970 Answers
Mcdevito75 here, Here is Timex Customer service info, 800-448-4639 hope they can help.
Posted on Aug 28, 2010
I WANT TO BUY NEW BEZELS FOR MY MARC ECKO WATCH : MODEL; E35000G1
The only place to get these is the manufacture or retailer. Try their website.
Oct 07, 2012 | Marc Ecko Mens Watch
Describe your tag heuer CN1111 replacement bezel Problem: The bezel came off & was lost
YOU have to buy new one. Will be costly. Check out e-Bay. Cheapest prices are there.
Feb 23, 2010 | Tag Heuer 2000 Exclusive Qtz Chrono...
How do i remove face of interchangeable watch?
This is called BEZEL you want to lift off. Take watch case opener (or just a pocket knife), insert the blade between case and bezel, then carefully pry up bit by bit, going all around the case. Make sure you are pressing blade in while prying up the bezel. This will not let knife to slip and scratch the watch. Rate me, plz.
Feb 12, 2010 | Avalon Medana Goldtone with...
My luminox watch needs a new bezel
You'll need a watchmaker to fit the new bezel. If it is just scratched I wouldn't recommend fixing it. You may pay 50$ for the new bezel and a pressure check; that may not be economical.
Oct 17, 2009 | Luminox Watches
Navitimer 2 rotating bezel has gone very stiff to turn how can i free it up?
This depends on what exactly is causing the problem. If the bezel is bent from a sharp blow it would have to be replaced. It could be there is dirt under the bezel. To clean this there are two possibilities. If your bezel has screws around the outer edge they will need to be loosened or unscrewed to remove the bezel. These are small screws so be careful you don't loose them. The bezel should then lift off. Clean it with mild soap and water and dry it well. Be careful of the bezel spring. it is easy to break the little fingers. Wipe off any dirt on the case and set the bezel spring and bezel back on the case. Use Red locktite on the screws and reinstall them. If you have markers on the bezel that come off when you remove the screws be sure you keep track of them and the screws that went with them.
If your bezel does not have screws but fake ones then the bezel should be removed by a qualified watchmaker because the bezel could be bent or damaged when removed.
Hope this helps.
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Watches
How to change bezel on Rolex Datejust
The bezel is secured by a Teflon gasket. To remove the bezel I would use a watch knife and gently press it in between the bezel and the case. Make sure you go straight in and it might not be a bad idea to use a layer of plastic around the knife so it doesn't leave marks. Also, do not use a widling motion. GO STRAIGHT IN. This will also prevent damage to the case and bezel. Repeat this several times working your way around the bezel. Be sure you don't continue to apply pressure with the knife once the bezel begins to come up as you don't want to damage the Teflon seal. Once you have the bezel out you will need to replace the Teflon seal the exact same way it came off on your replacement bezel and press back into place.
Sep 18, 2009 | Watches
Need new bezel
Try parsecent.com, you can get a replacement bezel there...
and you are right, you are basically buying a new watch as this model is made of plastic and cannot be 'polished'. Refurbishing it means that it will look new and everything on the outside would have to be replaced...good luck :)
Aug 07, 2009 | Luminox Navy SEAL Dive 3901 Wrist Watch
Replace mineral crystal in Zodiac Sea Dragon ZO-2201
Its better you bring your watch to a service center ,Because equipped of all the tools.
Hope it may helps;
Jun 16, 2009 | Zodiac "Sea Dragon" Watch
My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Feb 09, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch Logo
101 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
