Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
I need to know where to buy the parts that connect the the end of the pump , because mine is crack and leaking
  • 310 Answers
If you still need these item e-mail me here and i will get them for you.
adamh@newconceptchem.com
Posted on Oct 28, 2010
The trigger on my Ryobi pressure washer won't turn off and ter leaks out from it. Anyone know what the problem could be?
I had this problem as well. The valve inside the gun cracks causing it to leak. I repaired mine with fast setting epoxy and a hose clamp. Disassemble the gun taking note how the parts are assembled taking pictures helps. Look for the crack sometimes it is not very visible check the ends where parts come together. Mine was where the tube that the trigger connects to enters the tube where the hose connects to. Epoxy the OUTSIDE of the crack not inside the tube because it needs to be smooth in order for it to seal properly. Try to get some epoxy inside the crack then use the hse clamp to hold it together while the epoxy cures.reassemble the gun and test. Sometimes the O-Rings will need to be replaced oil the orings while assembling the gun to prevent damage to the orings.
Oct 25, 2016 | Garden
I need to buy a new block for my craftsman. mine has cracked and is leaking oil because the service centre I take it to didn't tension down the head. mine is a lawn tractor 17.5 hp 42 in deck.
Lindy, you can buy a new block at your local mower parts store. but replacing the whole engine with a used one would be a whole lot cheaper.
Oct 14, 2016 | Garden
Windshield wiper hose leak
Yes..
Remove the cracked hose and take it to parts store and buy a new hose get it about 1 inch longer than old one. Replace 1 end and put hose back in clips and measure how much you need to connect on the end and cut excess off put hose on fitting. This should have water flow agaig and no cracked hose.
B. J.
Apr 12, 2014 | 2005 Nissan Murano
Oil leak in the oil line running from the oil pump to the engine
goto local auto store buy a coupler for the oil line and the clamps cut bad section out of oil line and couple the ends together 5 bucks and its diy 10 minutes now if oil pump leaking youll need a replacement it could have crack
Nov 09, 2013 | 1999 Buick LeSabre
Power steering fluid leaking and turning is hard need to know how to change pump and hose need to know how to change it myself
First check the hoses located at the back of the pump. They are the most likely culprit.
If the fluid is leaking from the hose, purchase a replacement from a local dealer or repuitable auto parts supply.
If it is not the hose and the pump needs to be replaced, first I would suggest buying a Chilton manual either on-line or from an auto parts store and follow the detailed proceedure in replacing the pump.
This should require open end wrenches and take an hour or so.
Nov 25, 2010 | 2004 Chevrolet Monte Carlo
Are the power steering lines connected to the oil lines somehow? Just before my power steering crapped out, I would top up the pump reservoir only to blow white smoke out the tailpipe all the way home. How...
Hi. Your power steering pump hoses are closed looped. They run from the pump assembly to the reservoir.They do not run to any of your oil lines. Now, with that said, i would recommend to inspect your assembly for possible leaks. This is a high pressure setup that will produce leaks during hose or clamp failure. The reservoir can crack as well. This will cause fluid to leaks on the engine block or exhaust manifold, thus, causing the white smoke or burn off affect. Use the procedure below to inspect for possible loose hoses or compromised pump seals and reservoir issues.
Once you have staged your vehicle in a safe place, open the hood and locate your power steering system on your vehicle. The easiest way is to follow the part of the steering column assembly that goes through the firewall. Follow the components connected to the steering column all the way to the wheel assemblies and hoses connected to the power steering pump and reservoir. Attempt to scrub wet and dirty components around the steering system, using shop rags if the leak source is not readily apparent. Now,start the engine, rotating the steering wheel all the way from left to right several times to increase system pressure in the pump and hoses. Turn off the engine and inspect the system from the engine compartment, using a flashlight preferably. In some cases, you might have to wait one or two days for the leak to reveal itself . Next, check around the power steering pump, for possible cracks. If you find fluid around the pump case, the case is damaged and should be replaced. Some pumps are equipped with internal seals that may be replaced when necessary. Also, look around the reservoir and make sure it is in good condition. A cracked reservoir must be replaced as well.
Now, look around all fittings and hoses. A loose fitting cannot contain the high pressure in the system. Tighten clamps using a Phillips or flathead screwdriver or ratchet and socket, depending on the type of fitting or clamp used in your system. Additionally, check along the hoses for cuts. If possible, run your fingers along the length of the hose to find hidden wet spots. A hose leaking somewhere along the middle will have to be replaced. If the gash is very close to the end of the hose, you might be able to cut off the damaged part and reconnect the hose to the component. You will also need to Check the metal lines connecting the steering gear assembly to other components. A ruptured metal line must be replaced.
Lastly; Inspect completely around the rubber boots located between the ends of the steering gear assembly and the arms linking the assembly to the wheels. If fluid is leaking at either end, then the seals at the ends of the steering gear assembly will need to be replaced. If necessary, raise the front end of the vehicle using a floor jack and support it on jack stands or ramps. Once the vehicle is safely supported, inspect the steering gear assembly more closely to see if it is in good or bad condition . Make sure you check all the ares above for possible leaks or loose connections before replacing the entire pump.
Jul 05, 2010 | Toyota 4Runner Cars & Trucks
How do you change a water pump in a 97 pontiac firebird the car is loosing water and heating up and I don't think it's the thermostat
do u know for Sher its ur water pump ??should get it pressurized,,& find leak first,,other wise u will be changing wrong parts to fix ur problem,,& still have problem,,,
Feb 12, 2010 | 1997 Pontiac Firebird
My fuel pump on my cbr600fw is leaking. what could be the problem
Possibilities are: mount screws need to be tightened, tank is rusted through, cracked pump casing and bad fuel line connection.
Jan 17, 2010 | 1998 Honda CBR 600 F(3)W
Water leaking during drain and spin
Hi!
You Need to check the following--
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Rylee
Apr 03, 2009 | GE Washing Machines
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
53 people viewed this question
Top Aqua Flo Pool & Spa Experts
Jay Finke
Jay Finke
Gene Haynes
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
