Question about Philips Magnavox 42MF521D/37 Television
Phillips 42PFL5432D/37 tv turns on but turns off on its own constantly for no reason. it will turn on without a problem, but then a short time and its off
    Problem Solver:
  • 5 Answers
This sounds like a problem with the Small Signal Board (SSB). This is the main circuit board with RCA and HDMI jacks that you connect all your devices to.
There are about 5 surface mount 220uF capacitors on the lower left corner of the circuit board (as viewed from the rear). Replace these with same capacity and voltage rating and you should fine. They can be caps with regular leads. they do not need to be surface mount types.
One way to check if these caps are the problem is to warm the area with a hair dryer and see if this turns on the TV or keeps it on longer.
Posted on Apr 24, 2012
  • 4 Answers
Most likely the Power Supply has bad capacitors. check out badcaps.net for info. Someone else on there has the same LCD.
Posted on Nov 23, 2010
Philips 42pfl5432d/37 tv chirps when power is on
Usually stems from a short on the power supply board. I have a 37MF337B/37 37" that had the same problem. Turned out the set had 5 leaky capacitors and a shorted diode on the power supply board.
Jan 10, 2013 | Philips Televison & Video
I have a 42 inch LCD Phillips (42PFL5432D/37). The TV will not power up and the power button is flashing red and is making a chirping sound. Please Help.
I'm having the exact same problem with the exact same TV... capacitors are all good. I suspect a diode. will report back
Dec 03, 2010 | Televison & Video
Philips lcd tv 42pfl5432d/37 no picture
based on what you clarified and my experience I'd bet the problem is in one of the inverters, most likely the main inverter.
Look at the board part number - it's usually imprinted on the board itself - and look on eBay or Google for it.
Another way to go about it is to type in the model number (usually without /37) followed by the word "inverter", e.g. "42pfl5432d inverter".
My search yielded result board number VIT70023.80 and from there you start searching for this on eBay...find a reputable seller (like me, except I don't think I have it) and buy it.
It might be the slave inverter, it might be the master, but from what you describe it's more likely the master.
It's possible to nail it down, but it will require multimeter and some extra time.
Hope that helps!
Nov 15, 2009 | Philips Televison & Video
Power button will not come on either manually or with remote. Cable is working and power is on the circuit.
I have a Phillips. If you have a menu remote press tv. I panicked when that happened to me. I have RR and if you press the yellow A
and ctr at the top left for about 30 seconds should reset remote.
May 24, 2009 | Philips Televison & Video
No audio from cable through surround sound
you have to go to the setup for the TV audio and change it to audio out, not speakers.
May 07, 2009 | Philips Televison & Video
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 42MF521D/37 Television Logo
501 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
