Question about Haier Freezers
Running but not freezing. will go on and off. will go off and you can shake it and it will come back on
  • 21 Answers
Compresser gone
Posted on Sep 01, 2010
Making thumping noise
According to the manual it says there is a worn belt. Belt needs to be replaced.
Jan 19, 2014 | Grindmaster 5311 Bevgs - 1 Crathco Frozen...
We have a freezer full of fish and meat and it seems that the freezer is not freezing properly. The little green light at the bottom is flashing. Can you please tell us what we need to do as some of the...
Greetings,
This type of freezer has few controls to malfunction...is the compressor running? if it is...then, its most likely a sealed system problem....if not running...find the cold control and jump out the connectors..if it off due to bad control..this will bring it back on. the other thing that could keep it off is the relay..again, if cold control ok, then remove relay and shake it..if it rattles..its bad, This you need to actually replace. there is no temp fix...if everything I mentioned is okay and freezer compressor is actually running...its most likely a system failure and usually its one year from date of purchase
Bruce
Nov 25, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer does not freez food at all. the compressor motor run but no cool air or freez! Please advise any solution
Since you say the compressor is running, you should check the evaporator coil inside the cabinet. Remove the back wall screws, and the back wall, to expose the evaporator. If its fully encased in frost, like a square block of snow, you have a defrost problem, heater, t- stat or defrost control. If frost only at the top, your fan is not running. If its bare of frost, all you see is the aluminum coil, you have a sealed system leak of refrigeratnt
Oct 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
It won't freeze, fan blows but won't freeze
dear sir /madam
please check in your freezer,s back side there is compressor please try to find it,s running or not if it,s running and it,s not getting cool and not freezing inside then it can be low refrigerant gas problem it,s up to you ,refill the gas by yourself or take help to a technician.
hope answer the question
thank you
please vote!
Sep 13, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Will not freeze
either overload and relay or compressor run windings are bad
May 25, 2010 | True 11.4 cu. ft. / 323 liter Upright...
Some water dripping on the bottom and freezes onthe bottom of the freezer and sometimes theres water on the floor.
The freezer drain is cloged.Drain is in the bottom of the freezer floor in the back you may have to remove back panel. Run wire or somthing down drain tube to clear clog.
May 16, 2010 | Freezers
Top half does not freeze
There is a fan behind the back wall of the freezer about 1/2 way up from the bottom, you should be able to hear this running when the freezer is on. If you do not hear this then you need a new evaporator fan motor.
If you hear the fan run then you most likely have a problem with the automatic defrost cycle that would most likely be the heat element that is located just below the coils inside the freezer behind the panel.
Apr 21, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer stops
hi thanks for the question i would replace the thermostat what happens is the fridge will get nice & cold then shut off and not come on again shake it it comes on replace the thermostat thanks the appliance doc
Sep 25, 2008 | Freezers
Used frigidaire
look around the back of the freeze and at the bottom you will see a small black compressor .Put your hand on it and if it is running you will feel it vibrating. If it vibrating but running very hot them it means you have no gas in the system so the freezer won't freeze. If the compressor is cold and not running then it could be eaither the relay on the compressor or the board on the front either way you will need to get an engineer in
Dec 11, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
216 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
