Question about Brother EM-530 Typewriter
KB? Pitch? THe KB leds continue to flash constanly making a beeping noise. How do I fix this problem?
  • 106 Answers
Maybe your printer stuck,try to move him manually and then start typewritter
Posted on May 12, 2008
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
I have a a whirlpool dishwasher ADG7440
hold down the on button for 5secs it will reset
Jun 24, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
Pitch Beeping
make sure the printwheel is locked in place, and the cover is closed. otherwise it is probably the main board or power supply. take to a repair shop for evaluation
Aug 14, 2008 | Brother EM-530 Typewriter
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
Packard Bell
Check out the following link:
http://support.packardbell.com/uk/item/index.php?i=topic_02437&pi=platform_storeandsave3500&dhepn=C050890000
It includes the following:
Beeping noise and flashing LED
dot.gif dot.gif Situation dot.gifWhen I turn on the Store & Save, it makes a beeping noise and the LED flashes continuously. dot.gif Details dot.gifThese symptoms indicate that the AC adapter is not providing enough power. dot.gif Solution dot.gifThe AC adapter will need to be replaced. I hope this helps, Bob
Mar 24, 2008 | Computers & Internet
Brother EM-530 Typewriter Logo
96 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
